I wondering if anyone has had any luck getting the alarm/event sounds to work? I put a wav file in usr/share/zoneminder/sounds and enabled the function on the options screen but no sound. (mute is off and volume is up)
any ideas???
kevin
Alarm sounds ???
Maybe: http://www.zoneminder.com/forums/viewto ... larm+sound
Or search forums for "alarm sounds"...
