Hi all,
I have installed Zoneminder 1.22.3 on a Trixbox 2.4.20 distro (Centos 5 based).
The installation is ended ok without errors, but when I open Zoneminder Console and I go to "Stopped" link to activate Zm, nothing change; Is is always stopped.
Is there anyone can help me to solve the problem ??
thanks in advance
Zoneminder Console always "STOPPED"
/var/log/message
Feb 11 09:48:17 trixbox1 zmc_dvideo[3355]: INF [tele1: 5000 - Capturing at 9.80 fps]
Feb 11 09:49:59 trixbox1 zmc_dvideo[3355]: INF [tele1: 6000 - Capturing at 9.80 fps]
Feb 11 09:51:41 trixbox1 zmc_dvideo[3355]: INF [tele1: 7000 - Capturing at 9.80 fps]
Feb 11 09:53:23 trixbox1 zmc_dvideo[3355]: INF [tele1: 8000 - Capturing at 9.80 fps]
Feb 11 09:55:04 trixbox1 zmc_dvideo[3355]: INF [tele1: 9000 - Capturing at 9.90 fps]
Feb 11 09:56:46 trixbox1 zmc_dvideo[3355]: INF [tele1: 10000 - Capturing at 9.80 fps]
Feb 11 09:58:28 trixbox1 zmc_dvideo[3355]: INF [tele1: 11000 - Capturing at 9.80 fps]
Selinux is disabled
Selinux is disable:
/etc/sysconfig/selinux
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
# enforcing - SELinux security policy is enforced.
# permissive - SELinux prints warnings instead of enforcing.
# disabled - SELinux is fully disabled.
SELINUX=disabled
# SELINUXTYPE= type of policy in use. Possible values are:
# targeted - Only targeted network daemons are protected.
# strict - Full SELinux protection.
SELINUXTYPE=targeted
Selinux is disable:
SELINUX=disabled
- zoneminder
- Site Admin
- Contact:
same problem
hello, I have the same problem on a debian server.
Have you found a solution? thanks!
I solved this problem and posted the answer here:
http://www.zoneminder.com/forums/viewtopic.php?t=16476
