I am a newbie to zoneminder and perl. Please help me on calling other programs from the zoneminder. Can I use the following code on this.
#!/usr/bin/perl -w
use strict;
use ZoneMinder;
$| = 1;
my $sql = "select M.*, max(E.Id) as LastEventId from Monitors as M left join Events as E on M.Id = E.MonitorId where M.Function != 'None' group by (M.Id)";
my @monitors;
push( @monitors, $monitor );
while( 1 )
next if ( !zmMemVerify( $monitor ) );
# Do your stuff here
sleep( 1 );
