Can only get one port working on a Conexant Fusion 878A chip
styro
Post by styro »
I hope someone can help me. I have a Lorex QLR0440 4 port single chip card. I'm able to get video on video0 channel 0 but channels 1-3 only blue screen with timer/clock bar. Channel 4 will show channel 0 video, don't know why but there it is. I've been googling and searching this site for a fix for 6 days, seen a few post with same problem but no solution. I'm able to use card #'s 77, 0, 98, and 133 with the same results. Here is output from zmu -d /dev/video0 -q -v with card #98. Other #'s give same output.
Video Device: /dev/video0
General Capabilities
Driver: bttv
Card: BT878 video (ProVideo PV150)
Bus: PCI:0000:05:04.0
Version: 0.9.18
Type: 0x5000015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 2
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Card works with all 4 ports in windows but I hate windows! I've only been using Ubuntu off and on for the last year or so, I usually use a mac and wasn't able to port a driver from FreeBSD, that was another long nightmare. I'm hoping I won't have to use windows for this card.
This is error/warning message I recieve when I change channel to 1-3 :
WAR [Can't find process with command of 'zma -m 1']
I've googled that and can't find anything on it.
Styro
