(FIXED)-Zoneminder working in a Guruplug server plus but...
PacoLM
Post by PacoLM »
I have setup my recently acquired Guruplug server+ to work with Zoneminder 1.24.2 after some troubles, but finally it works!!!
I connect to him remotely using Firefox (tried also with Opera & Galeon), and seems that some buttons of the web interface does not work as expected.
For instance: if I click in a monitor, is not possible to see other tab than "General", if I click over "Source" or 'Misc" for instance, the browser does nothing.
I made a workaround copying the link and adding the '&tab=tabwanted', that way I was able to setup two monitors. The problem is setting up the zones, the points and initial area that usually is green is not shown at all...
I've read some posts time ago talking about something similar, but couldn't find them.
The guruplug is running debian:
# uname -a
Linux sheevaplug-debian 2.6.32-00007-g56678ec #1 PREEMPT Mon Feb 8 03:49:55 PSTx
Thanks in advance,
PacoLM
PacoLM
Post by PacoLM »
Hi again,
Has this anything to do with mootools?. I've read some posts about this tools, but I'm not sure...help please!
Thanks in advance,
PacoLM
PacoLM
Post by PacoLM »
Note to self:
I have manually edited the zone settings and copied them from my existing working system. At this moment,the guruplug is working as modect wih one camera, and seems to be working better than my Ubuntu PC, in the test, all the movement is captured in one event (in guruplug) while the same movement is captured in 2 different events in the Ubuntu PC. Why is this happenning if the settings are exactly the same????
PacoLM
PacoLM
Post by PacoLM »
No one could help in the 'buttons not working'?. Anyone experienced this before?
TIA
PacoLM
Post by PacoLM »
FIXED myself (ole mis huevos)
subnic
Post by subnic »
Si señor :)
PacoLM
Post by PacoLM »
:lol:
