1. I think, there will be a useful idea if to make the analyzer of a direction of movement of object. I.e. to show a way of his movement.
For example, it is possible to allocate transitions of object from a zone in a zone, i.e. to allocate such events as, for example, an output, an input, etc....
2. Also I believe not bad to enter into the project the graphic plan (map) of protected object with the pictograms of the security equipment placed on it. map - powerful and extremely convenient means of designing and support of security system. Badges of a map link with the real equipment. For example click under the icon of the chamber the window of viewing of video from this chamber also opens....
I think this opportunity can seriously improve functionality of system of supervision.
Only it is necessary to think as it better to organize. But general idea I think it is clear?
Direction of movement of object
- zoneminder
- Site Admin
- Contact:
These are both very good ideas and make things easy for a user. Unfortunately they also take rather a lot more programming to do well. Nevertheless adding further enhancements to the interface is something I'd very much like to add in the future and your ideas (especially no 2) are the kind of thing I'd like to do.
Phil
Phil
- zoneminder
- Site Admin
- Contact:
I think direction of movement and tracking is something I'm planning to do do anyway, as I'm implementing a PTZ interface and I'd like to be able to auto fix on motion.
You second idea you can just go ahead and try it out. Post some details here when you've got something to show and see what people think, or if they have any ideas or suggestions.
Phil
Phil
Today, I for experiment started to write frontend for windows. The first experimental release, I think, will appear in ~ two weeks since becouse me practice in courts now began, and I have not enough free time...
On results of my expirements I shall periodically inform...
Except for that I have still an idea on completion ZM:
I think, it is useful to make the analyzer which would show the brought objects and as carried away. For example, the person has left a bag or a box and go away, the system should allocate somehow this brought thing in the staff since she can bear threat. Except for that it is possible to collect photos of these objects for the further viewing that have dragged off or have brought
