Newbie with Pico2000 and ClearOS
speedamaster
Post by speedamaster »
hi,
I fail to get a video on my screen with an Pico2000 card.
In /etc/modprobe.conf I have
options bttv card=77 tuner=4 radio=0 triton1=0 vsfx=0 autoload=0
dmesg|grep bttv gives
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bt878: waiting for bttv to get alive
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:05:04.0, irq: 74, latency: 32, mmio: 0xe8200000
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00f360ff [init]
bttv0: using tuner=4
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
and dmesg|grep bt878 gives
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
bt878_probe: card id=[0x0],[ <NULL> ] has DVB functions.
bt878(0): Bt878 (rev 17) at 05:04.1, irq: 74, latency: 32, memory: 0xe8201000
in the ZM console I added 2 monitors with
/dev/video and channels 0 and 1 PAL, rgb24, 320x240, Video4Linux1 and maxFPS 5.0
NO VIDEO....
any help?
Marcio
Post by Marcio »
Change
/dev/video
to
/dev/video0
speedamaster
in /dev video is a link to video0, so this didn't help.....
anything else I could check?
bristoldave
Post by bristoldave »
He means change /dev/video to /dev/video0 in the ZM options :)
speedamaster
this is what I did. In ZM config for the monitor..... I just mentioned that anyway /dev/video is linked to /dev/video0 so it shouldn't make a difference if I have in ZM /dev/video of /dev/video0....
anyway.... not solved yet...... :-(
speedamaster
BTW: if I create a new monitor and press "probe" I get the error
Unable to probe local cameras, status is '255'
zmu -d /dev/video0 -q -v
Error, failed to query crop capabilities /dev/video0: Invalid argument
/etc/zmdc.log gives
30.12.2009 16:25:47.006907 zmdc[4657].INF [Starting pending process, zmc -d /dev/video0]
30.12.2009 16:25:47.009300 zmdc[4657].INF ['zmc -d /dev/video0' starting at 09/12/30 16:25:47, pid = 15874]
30.12.2009 16:25:47.068048 zmdc[4657].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
speedamaster
No help out there?
p.eldhose
Post by p.eldhose »
speedamaster wrote:BTW: if I create a new monitor and press "probe" I get the error
/etc/zmdc.log gives
me too having same problem .....
pls some body helppp...
georgik
Helping
Post by georgik »
Hi, I was writing something about pico2000
http://www.zoneminder.com/forums/viewto ... highlight=
Maybe this helping you!
bb99
Post by bb99 »
Within ZM, if you don't specify /dev/video0 the source will turn red (not working) regardless of links. Just tested on working Fedora 12 box by creating link and changing source to /dev/video which resulted in broken capture. When using a capture card, ZM is married to the card, the camera can't be probed and the resolution, palette, format, etc, are determined by the card only so your source settings need to be based on the card output only.
