openSuse11.3X64/KDE4.5.2/ZoneMinder, v1.24.2/Bus 006 Device 002: ID 046d:092f Logitech, Inc. QuickCam Express Plus
When I use the ZoneMinder LiveCD (downloaded today), my camera works fine, but when using my opensuse setup, everything SEEMS to work, but when I try and view video, where the video should be, I get an empty box with the monitor name in it... Have tried copying the source settings from the live cd, but this doesn't help. Camera works fine in XAWTV and zmu -d /dev/video0 -V1 -q -v gives:
Video Device: /dev/video0
Video Capabilities
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 352
Maximum Height: 288
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 8
Brightness: 0
Hue: 32768
Colour :0
Contrast: 0
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
In the ZMDC.LOG file I am getting:
11/01/10 20:32:46.050227 zmdc[10919].INF [Starting pending process, zmc -d /dev/video0]
11/01/10 20:32:46.051048 zmdc[10919].INF ['zmc -d /dev/video0' starting at 10/11/01 20:32:46, pid = 11198]
11/01/10 20:32:46.322663 zmdc[10919].ERR ['zmc -d /dev/video0' exited abnormally, exit status 11]
and in the system log:
Nov 1 20:57:14 boss zmdc[11667]: INF [Starting pending process, zmc -d /dev/video0]
Nov 1 20:57:14 boss zmdc[11667]: INF ['zmc -d /dev/video0' starting at 10/11/01 20:57:14, pid = 11736]
Nov 1 20:57:14 boss zmdc[11736]: INF ['zmc -d /dev/video0' started at 10/11/01 20:57:14]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: INF [Debug Level = 0, Debug Log = <none>]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: INF [New Debug Level = 5, New Debug Log = /var/log/zm/zm_debug.log.11736]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: INF [Starting Capture]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: WAR [Contrast control is not suppported]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: WAR [Brightness control is not suppported]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: INF [Brightness 1 0]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: WAR [Saturation control is not suppported]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: INF [Got signal 11 (Segmentation fault), crashing]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: ERR [Signal address is 66054, no eip]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: ERR [Backtrace: /lib64/libpthread.so.0(+0xf2e0) [0x7f029e80a2e0]]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: ERR [Backtrace: /usr/bin/zmc() [0x41a6e8]]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: ERR [Backtrace: /usr/bin/zmc() [0x4257e6]]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: ERR [Backtrace: /usr/bin/zmc() [0x405b9a]]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: ERR [Backtrace: /lib64/libc.so.6(__libc_start_main+0xfd) [0x7f029d783b7d]]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: ERR [Backtrace: /usr/bin/zmc() [0x405499]]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: INF [Backtrace complete, please execute the following command for more information]
Nov 1 20:57:14 boss zmc_dvideo0[11736]: INF [addr2line -e /usr/bin/zmc() 0x7f029e80a2e0 0x41a6e8 0x4257e6 0x405b9a 0x7f029d783b7d 0x405499]
Nov 1 20:57:14 boss zmdc[11667]: ERR ['zmc -d /dev/video0' exited abnormally, exit status 11]
The only other thing that I am a little bit dubious about (meaning: they're different, but I don't know enough to figure out why...) lsmod on the working live CD has:
gspca_spca561 9684 1
gspca_main 21684 2 gspca_spca561
but on the not working real pc is:
gspca_spca561 10987 0
gspca_main 30247 1 gspca_spca561
(being used by an extra process??)
Thanks, John.
Quickcam express probs
