I am running ZM 1.19.5 on Knoppix (3.7) that has been installed to Hard Disk.
I had a little trouble getting ZM to run initially, but for the last 2 months or so it has been working reliably.
The only way i could get my devices to turn green was to change from modetect to monitor, trying to run any other way didnt work, still i was happy as i did have a working system.
My eventual aim was to be able to run direct from a remastered Knoppix CD, and i am still working on this, and will release this if / when i ever get it working, with this in mind i tried to get the zm script in the /etc/init.d directory to work, during this attempt i have broken my hdd version.
The first hint of this in the logfiles (zmdc.log) is
"Can't locate MIME/Entity.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.4 /usr/local/share/perl/5.8.4 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl) at /usr/local/bin/zmfilter.pl line 87."
Now zmc wont start, this shows up in the same log file as "Can't bind: Address already in use at /usr/local/bin/zmdc.pl line 166"
Can anyone give me a hint as to what has gone wrong ?.
Here is a section of the zmdc.log.
Can't bind: Address already in use at /usr/local/bin/zmdc.pl line 166.
Starting pending process, zmfilter.pl
'zmfilter.pl' starting at 05/02/02 20:09:49, pid = 32309
'zmfilter.pl' started at 05/02/02 20:09:49
BEGIN failed--compilation aborted at /usr/local/bin/zmfilter.pl line 87.
'zmfilter.pl ' crashed at 05/02/02 20:09:49, exit status 2
'zmc -d 0' died at 05/02/02 20:10:21
'zmc -d 0' starting at 05/02/02 20:10:21, pid = 32364
'zmc -d 0' started at 05/02/02 20:10:21
Server starting at 05/02/02 20:10:32
zmc(32364): Operation not permitted
zma(30344): Operation not permitted
zma(30353): Operation not permitted
zmaudit.pl(30362): Operation not permitted
zmwatch.pl(30367): Operation not permitted
zmupdate.pl(30374): Operation not permitted
Server starting at 05/02/02 20:10:42
Server starting at 05/02/02 20:10:52
Server starting at 05/02/02 20:11:03
Can't bind address problems.
- zoneminder
- Site Admin
- Contact:
You can ignore MIME::Entity as that just applies to emailed filters, though it won't hurt to install it otherwise filters won't work automatically.
The bind problem is just a general socket problem in that zmdc can't start as the address (or socket file in this case) it wants to use is still in use by something else. Most likely a previous instance of zmdc.pl. You should shutdown zm and then make sure all zm processes are gone before trying to restart which should hopefully fix it.
Phil
Phil
Thanks for the advice regarding Entity.
As for the other problem, i guessed it was a socket problem, however a reboot didnt fix the problem (tried this 2 or 3 times) .
I did manage to eventually fix the problem, while in the /tmp directory i noticed a "zm sock" file (sorry cant remember the exact name) , and deleted this and ZM started working again, hope this helps someone in the future.
It still wont work from the startup script, any hints on how to get this to work under Knoppix would be very well recieved.
As a reminder the only way i can start ZM is to change from say "Modetect" to "Monitor" (using Function) , I have to do this with all 4 cameras to get the corresponding "source" to turn green. If i click on Running (or indeed Stopped) and select a different action, then the state of ZM does not change, EG , if i select Stop, ZM does not stop, if i select start it does not start.
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
Ooops, sorry. I don't know where I got Knoppix from! I think I must have had it on the brain that day.
I don't know if this applies to Knippix but Slackware for example doesn't like the syntax of some of the 'su' commands in the scripts. You could try search the forum for slackware and applying the same changes. Actually there is a document in the Documentation section that describes them. It was originally written for an older version of ZM but it should pretty much apply still.
Phil
Phil
