Hello everybody,
i'm using zoneminder v1.22.3 on a 2,4Ghz with 512Mb Ram celeron machine.
Input card is a 4-port Bttv878 card.
I have one camera attached.
The camera resolution is 582x500 pixel.
(I could not set up ZM to the native camera resolution...)
So the input resolution is 576 x 432 pixel.
The image quality ist good when there is no moving object.
But when something moves
the sharpness of the object edges is very bad.
For example the postman in the attached image:
Look like an interlacing problem - is there any solution fot that problem?
Regards,
Thorsten
Bad image quality when motion
Same here...
Hello
Same type of image quality glitch on my camera images.
Anyone got any ideas?
J
J
