Image Buffer Size (frames) set to 200
Pre Event Image Count set to 180
Post Event Image Count set to 180
The following occurs:
Nov 9 12:38:58 router zma_m12[1804]: INF [IP7330: 741 - Gone into prealarm state]
Nov 9 12:38:58 router zma_m12[1804]: INF [IP7330: 743 - Gone into alarm state]
Nov 9 12:38:58 router zma_m12[1804]: INF [IP7330: 743 - Opening new event 77628, alarm start]
Nov 9 12:39:00 router zma_m12[1804]: ERR [Can't insert frames: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1]
Nov 9 12:39:00 router zmdc[21931]: ERR ['zma -m 12' exited abnormally, exit status 40]
Nov 9 12:39:00 router zmdc[21931]: INF [Starting pending process, zma -m 12]
Nov 9 12:39:00 router zma_m12[2002]: INF [IP7330: 026 - Gone into prealarm state]
Nov 9 12:39:00 router zma_m12[2002]: INF [IP7330: 028 - Gone into alarm state]
Nov 9 12:39:00 router zma_m12[2002]: INF [IP7330: 028 - Opening new event 77629, alarm start]
Nov 9 12:39:02 router zma_m12[2002]: ERR [Can't insert frames: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1]
Nov 9 12:39:02 router zmdc[21931]: ERR ['zma -m 12' exited abnormally, exit status 40]
Nov 9 12:39:07 router zmdc[21931]: INF [Starting pending process, zma -m 12]
Id Name Time Secs Frames Score
77629 New Event 2010-11-09 12:38:52 0.00 null/null 0/0 X
77628 New Event 2010-11-09 12:38:50 0.00 null/null 0/0 X
