Ok, heres a weird question.
I installed ZONEMINDER and all worked well (after a few probs with FFMPEG -but got those fixed). So all was cooking along nicely when I had a router problem. No ip going over the wire whatsoever (it was quite strange). So after fixing my physical network, I ended up changing the ip of the ZM box and a few cameras.
Here is the problem: No cameras that are setup (changed IP or not) are able to be clicked on the console screen. Just the camera itself. I can go into the setup, change the function, but cant click on the camera name to view it. ALSO: I cannot click on CYCLE or MONTAGE.
I am guessing something has happened to apache or similar when the IPs changed.
ANY IDEAS?
