Zoneminder 1.23X /var/cache/zoneminder/events is full
I forget to setup the purge filter to clean the hdd after it reaches the 90 threshold and /var/cache/zoneminder/events is full. I have deleting the events under /var/cache/zoneminder/events manually and then I will attempt to start zoneminder again. It this the correct way to do purge the hdd if it gets full?
