Well, after a bit of hacking around with page source on the camera, I put together a string that let me change the settings using the Safari browser or FireFox:
http://admin:1234@192.168.2.3/form/came ... a_left.asp
Options are as follows:
Resolution:
0 = 640x480
Quality:
3 = Highest
Frame Rate:
30 = 30 frames per second (FPS)
25 = 25 FPS
20 = 20 FPS
15
10
5
3
1
Frequency:
60 = 60hz
50 = 50 hz
0 = "Outdoor" mode
Auto Exposure:
ON /OFF
Others are Black, White, Brightness - defaults *should* work ok, but you can tweak for your environment. For me, the defaults worked ok.
I hope this is helpful.
Anyhow, this thing is Linux based, we ought to be able to make a new firmware and Open Source it, RIGHT? The reason I am asking you all about this is because I have problems with my camera freezing after about 7 hours every day. The ethernet works, but the camera stops producing JPG images. VERY STRANGE. Anyone else having this problem? Have you found a fix to it besides power cycling? Firmware is already the latest version. Also I have bricked TWO of these cameras after uploading the firmware from WindowsXP using IE. Anyone else have this issue? Thanks in advance. Please post response and email.
tman@techmundial.com
