NO ZONES button - Ubuntu 9.10 Server & ZM 1.24.2 -
scarrz
Post by scarrz »
I just recently installed from scratch ubuntu 9.10 and 1.24.2 of ZM and the video of all 8 cameras appears to work correctly, although a few of them seem to have some interlacing. The problem is when I select a camera to do MODECT nowhere do I see the ZONES button that used to appear when you clicked on the camera? I'm at a loss. I would like to setup motion zones but there is no button??? Anybody have some advice??
forgot to add im using Firefox 3.6.12 to view.
Thanks.
PacoLM
Post by PacoLM »
I had the same problem, it's was soled by updating the system :
apt-get upgrade
apt-get update
Hope it helps,
PacoLM
scarrz
Post by scarrz »
Thanks for the tip. I just tried it but nothing changed. still no ZONES button. Very strange and not sure what else to do other than reinstall.
PacoLM wrote:Hi,
apt-get upgrade
apt-get update
Hope it helps,
PacoLM
