I am getting this error message in apache logs
"Too many open files in system"
is it related to zoneminder ? or not ?
any resolution?
I think it's related, but I don't know the answer... reason being that I started getting this after in stalling ZM too, and haven't figured out. I just have to reboot every few days
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
I definatelly do not like to be babysitter of my Zoneminder ...
The problem is when someone watch monitor for too long ...
the file descriptor of the system by default is 1024
you can see it with
# ulimit -a
I hope I found the answer , I am testing it now ....
editing
apachectl (mine is here - /usr/sbin/apachectl )
and adding
ULIMIT_MAX_FILES="ulimit -n 16384"
you can also take a look here, where I found this answer :
http://serverfault.com/questions/20183/ ... -in-system
you can see it with
# ulimit -a
editing
and adding
Zoneminder uses alot of open files when it's using mapped memory.
Linux has a set limit of how many files that can be opened at the same time. You can see the current limit:
To change the max, you can edit the /etc/sysctl.conf. So for example, your current max is at 5000 and you want to change it to 10000. You add the line to your /etc/sysctl.conf file:
To make the change go into effect, you then run
cat /proc/sys/fs/file-max
fs.file-max = 100000
sysctl -p
I increasing the file max to double the size of your current amount.
So if "cat /proc/sys/fs/file-max" returns n
Set the max to 2n
If the /etc/sysctl.conf file doesn't exist go ahead and create one.
I should have mentioned that you'll only need to run sysctl -p just to make the new settings in sysctl.conf go into effect without needing to reboot the computer. You won't have do call that program everytime you computer starts up.
Set the max to 2n
