Export Events ... Help !!!
jarod159
Post by jarod159 »
Hi at all!
I need to export events so i followed this guide to export events ...
http://www.zoneminder.com/wiki/index.ph ... ent_Filter
but i can't locate the file zmEventImagesMaster.html to browse through events...
Any help ???
Thanks a lot!!!!!
bb99
Post by bb99 »
To locate and export or create a video and then export: Bring up your browser with ZM loaded, select the name of the camera, find the event you want to export or create a video of and select it, across the top of the window (popup) you'll see the export and video choices, select what you want to do...
jarod159
Post by jarod159 »
bb99 wrote:To locate and export or create a video and then export: Bring up your browser with ZM loaded, select the name of the camera, find the event you want to export or create a video of and select it, across the top of the window (popup) you'll see the export and video choices, select what you want to do...
Thanks a lot ...
But I'm referring to the export of more events... that is:
1. Go to Filter Page
2. Check Create video for all matches
3. The system show the filter page with the events filtered
4. I select all the events and click to export
(Video if present) - Tar Compression
At the end i obtain a tar file with the results but i can't locate the "EventImagesMaster.html" to browse through events like described in
Thanks a lot !!!!
