i've got it, now seeding both, its past midnight here, once i finish my work over the weekend i will try it.bb99 wrote:Should be able to get 250 to 300 KB/s from me alone unless space and time prevent it. Just a suggestion: consider Fedora, it is very solid (Fedora 12 following the installation steps from the wiki, "the easy way", I posted it so cut and paste is possible with all entries included, none of this "usual way" stuff). Just responded to a Fedora 14 pm so the instructions are still good. Don't know what happened to Ubuntu but sure seems to be allot of issues... Just updated Fedora (not a ZM box) from F12 to F14 with no issues at all, finally a true rolling release; I'm hooked!
Connexant BT878A Chip Set-Up / ZM 1.24.2
Dan.Tech
OK tried both those, and no better. So at the weekend I reinstalled Mandriva2007 Live CD and Zoneminder worked fine. I couldn't get Fedora to install at all on my PC. So now back to Ubuntu, and find I have to set cameras to NTSC and GREY to get any picture at all, where I got colour pictures with PAL and RGB24 under Mandriva.
Do you want me to continue on this thread or start a new one? I think this is an issue with 1.24 on Ubuntu, as the card works fine with other versions of OS.
I've taken out autoload as there was a message that it was obsolete.
Currently dmesg shows:
~$ dmesg | grep bttv
[ 6.298144] bttv: driver version 0.9.18 loaded
[ 6.298148] bttv: using 32 buffers with 2080k (520 pages) each for capture
[ 6.298915] bttv: Bt8xx card found (0).
[ 6.298958] bttv 0000:03:08.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 6.298977] bttv0: Bt878 (rev 17) at 0000:03:08.0, irq: 17, latency: 16, mmio: 0xfdeff000
[ 6.299005] bttv0: using: IVC-200 [card=102,insmod option]
[ 6.299068] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 7.100013] bttv0: tuner type=0
[ 7.146803] Modules linked in: msp3400 snd_hda_codec_realtek ir_lirc_codec lirc_dev snd_hda_intel ir_sony_decoder snd_hda_codec snd_hwdep snd_pcm ir_jvc_decoder bttv(+) ir_rc6_decoder snd_seq_midi snd_rawmidi v4l2_common videodev v4l1_compat videobuf_dma_sg videobuf_core ir_rc5_decoder nouveau snd_seq_midi_event btcx_risc ir_nec_decoder ir_common ir_core tveeprom snd_seq snd_timer snd_seq_device ttm drm_kms_helper ppdev parport_pc shpchp led_class drm snd i2c_algo_bit intel_agp agpgart psmouse soundcore snd_page_alloc lp parport serio_raw skge floppy
[ 7.147228] [<f83e1546>] ? T.761+0x36/0x40 [bttv]
[ 7.147244] [<f83e7d62>] ? bttv_init_card2+0xb33/0xbba [bttv]
[ 7.147286] [<f83e817e>] ? init_bttv_i2c+0x1b2/0x248 [bttv]
[ 7.147302] [<f83e6440>] ? bttv_probe+0x573/0x843 [bttv]
[ 7.147452] [<f82a90d6>] ? bttv_init_module+0xd6/0xee [bttv]
[ 7.147476] [<f82a9000>] ? bttv_init_module+0x0/0xee [bttv]
I'm beginning to think this might be a resource issue. If I uninstall and then reinstall ZM I get a different set of cameras working each time. I have six of the eight ports on the card connected to cameras, and on three successive reloads of ZM the monitors that worked were 2,3,5,6 then 1,3 and 5 and finally 1,2 and 6, so no real pattern to it at all.
hiya again, it's me. i haven't forgotten about this thread, i've just about finished with most of my work meaning i have time to work on this system, it's taken far too long but hey, what can i do? okay so i put ZMLinuxOS on a disc and ran the live CD, it doesn't help that i'm a newbie to linux so i might sound completely stupid. I put the card in, opened ZM in firefox and set up monitors as usual, i couldn't find a text editor to edit the options.conf or make the bttv.conf supplied in the instructions, it looked more hopeful though, when i ran lspci it recognised the BT878 card 8 times (one for each channel the card has) but came up with video 8 times then audio 8 times when this card is video only
I set my monitors to /dev/card0 because that's what it was listed as, there were no other video sources under /dev, i tried to take a print screen (through the menu somewhere) but failed completely nothing went into the clipboard or saved on the desktop, i couldn't get it to connect to the internet either so i just took pictures with a digital camera, lspci and dmesg (but came up a million times in dmesg saying reset, reinitialize_ both recognise the card yet kmplayer can't pull a stream off the card, it just buffers then says: mplayer not running, nothing showed a picture, i did have each input connected with a camera so i really don't know what's going on
hopefully you can help me on this, all will be appreciated, happy holidays and happy new year to all
Dan.Tech
Take a look at this:http://www.zoneminder.com/forums/viewtopic.php?t=16993 . The card listed can be a tough one.
