I compiled libjpeg-turbo and ran make install, I was wondering if anyone out there knew how I can confirm its work?
Doesnt seem my CPU usage dropped so im guessing its not being used.
I ran 'export LD_LIBRARY_PATH=/opt/libjpeg-turbo/lib64'
And I verified this is where the software is.
libjpeg-turbo running or not running?
Figured it out... Thanks! Once you said sym link it got me to where I needed.
Noticeable improvement about 1/2 the CPU from before.
# ls -l /usr/lib/libjpeg.so.62
lrwxrwxrwx 1 root root 17 2010-11-12 12:35 /usr/lib/libjpeg.so.62 -> libjpeg.so.62.0.0
# rm -rf /usr/lib/libjpeg.so.62
# ln -s /opt/libjpeg-turbo/lib/libjpeg.so.62.0.0 /usr/lib/libjpeg.so.62
http://foss-boss.blogspot.com/2010/11/s ... cloud.html
This library would be pretty useless once:
1) your video cameras feeds ZoneMinder with MPEG videos, and not M-JPEG
2) ZMA stores the events as x264 video files, and not JPEG sequences
3) ZMS streams in MPEG format
I really can't wait for warmcat's x264 contribution to be accepted and included in the latest revisions of ZM 1.24.2
I'm not familiar with that specific card, but am with the chipset. What motherboard are you using the card with, there are a few known to cause irratic behavior or just not work at all.
Even though it is being picked up, you will still need to tell it that there are 4 channels there.
add the following to /etc/modprobe.conf
options bttv card=77
You can access the cameras with these settings.
/dev/video0 Channel: 0-3
I never recommend viewing the cameras directly from the server but use the web interface on another computer. If using IE to view you will have to install a java file on the server it's self.
