Monitor never leaves orange status
bparker
Post by bparker »
I just installed zm-1.20.0 and whenever I add a new monitor and change the status to anything besides 'none', it stays orange and zma never starts. Trying to run it manually via 'zma -m <id>' exits with a code of 255. Any ideas? I'm running Debian Sarge, BTW.
zoneminder
Site Admin
Post by zoneminder »
Have you gone through the steps in the troubleshooting guide? ANything in /var/log/messages?
Phil
bparker
Post by bparker »
Nothing unusual in the logs, where is the troubleshooting guide at?
This is the last bit of output from strace:
gettimeofday({1107440179, 452009}, {360, 0}) = 0
time([1107440179]) = 1107440179
getpid() = 7879
rt_sigaction(SIGPIPE, {0x4088d7a0, [], SA_RESTORER, 0x40772678}, {SIG_IGN}, 8) = 0
socket(PF_FILE, SOCK_DGRAM, 0) = 4
fcntl64(4, F_SETFD, FD_CLOEXEC) = 0
connect(4, {sa_family=AF_FILE, path="/dev/log"}, 16) = -1 ENOENT (No such file or directory)
close(4) = 0
rt_sigaction(SIGPIPE, {SIG_IGN}, NULL, 8) = 0
exit_group(-1) = ?
zoneminder
Site Admin
The troubleshooting guide is in the README file.
Phil
bparker
Post by bparker »
Running 'zmu -d 0 -q -v -U admin -P admin' segfaults...
bparker
Post by bparker »
any ideas on how to diagnose that?
zoneminder
Site Admin
If you have gdb then do
gdb zmu
run  -d 0 -q -v -U admin -P admin
then when/if it crashes do
bt
and post the results.
Phil
bparker
Post by bparker »
Starting program: /usr/local/bin/zmu -d 0 -q -v -U admin -P xxxxxxxx
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 1135)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 16384 (LWP 1135)]
0x40775ebe in __strtol_internal () from /lib/libc.so.6
(gdb) bt full
#0  0x40775ebe in __strtol_internal () from /lib/libc.so.6
No symbol table info available.
#1  0x08060b3e in User (this=0xd1b1e48, dbrow=@0xbfffb80c) at stdlib.h:316
        monitor_ids_str = 0xbfffb80c "È]\033\rselect Username, Password, Stream+0, Events+0, Monitors+0, System+0, MonitorIds from Users where Username = 'admin' and Password = password('xxxxxxxx') and Enabled = 1"
#2  0x08060d3a in zmLoadUser (username=0xd1b1e48 "admin", password=0x408900cc "@û\205@@\t\206@@\003\206@ \211\207@")
    at zm_user.cpp:133
        sql = "select Username, Password, Stream+0, Events+0, Monitors+0, System+0, MonitorIds from Users where Username = 'admin' and Password = password('xxxxxxxx') and Enabled = 1", '\0' <repeats 8024 times>
        result = (MYSQL_RES *) 0xd1b1de0
        n_users = 1082720460
        dbrow = 0xd1b5dc8
#3  0x0804af31 in main (argc=134642259, argv=0xbffffd54) at zmu.cpp:321
        user = (User *) 0x408900cc
        long_options = {{name = 0x8064632 "device", has_arg = 1, flag = 0x0, val = 100}, {name = 0x8064639 "monitor",
    has_arg = 1, flag = 0x0, val = 109}, {name = 0x8064641 "verbose", has_arg = 0, flag = 0x0, val = 118}, {
    name = 0x8064649 "image", has_arg = 2, flag = 0x0, val = 105}, {name = 0x8069448 "scale", has_arg = 1, flag = 0x0,
    val = 83}, {name = 0x806464f "timestamp", has_arg = 2, flag = 0x0, val = 116}, {name = 0x8064659 "state", has_arg = 0,
    flag = 0x0, val = 115}, {name = 0x806465f "brightness", has_arg = 2, flag = 0x0, val = 66}, {name = 0x806466a "contrast",
    has_arg = 2, flag = 0x0, val = 67}, {name = 0x8064673 "hue", has_arg = 2, flag = 0x0, val = 72}, {
    name = 0x806466a "contrast", has_arg = 2, flag = 0x0, val = 79}, {name = 0x8064677 "read_index", has_arg = 0, flag = 0x0,
    val = 114}, {name = 0x8064682 "write_index", has_arg = 0, flag = 0x0, val = 119}, {name = 0x806a69d "event", has_arg = 0,
    flag = 0x0, val = 101}, {name = 0x806468e "fps", has_arg = 0, flag = 0x0, val = 102}, {name = 0x8064692 "zones",
    has_arg = 0, flag = 0x0, val = 122}, {name = 0x806469a "alarm", has_arg = 0, flag = 0x0, val = 97}, {
    name = 0x8064698 "noalarm", has_arg = 0, flag = 0x0, val = 110}, {name = 0x80646a0 "cancel", has_arg = 0, flag = 0x0,
    val = 99}, {name = 0x80646a7 "query", has_arg = 0, flag = 0x0, val = 113}, {name = 0x80646ad "username", has_arg = 1,
    flag = 0x0, val = 85}, {name = 0x80646b6 "password", has_arg = 1, flag = 0x0, val = 80}, {name = 0x80646bf "help",
    has_arg = 0, flag = 0x0, val = 104}, {name = 0x0, has_arg = 0, flag = 0x0, val = 0}}
        dev_id = 0
        mon_id = 0
        verbose = true
        function = QUERY
        image_idx = -1
        scale = -1
        brightness = -1
        contrast = -1
        hue = -1
        colour = -1
        username = 0xbffffe71 "admin"
        password = 0xbffffe7a "xxxxxxxx"
        auth = 0x0
password was changed to x's, that's all
this is the normal bt output:
(gdb) bt
    at zm_user.cpp:133
zoneminder
Site Admin
Hmm, that looks a little strange. If you do a select on the Users table can you post what values you see (I'm interested in what might be NULL or otherwise). Also what the values of dbrow are in gdb.
Phil
bparker
Post by bparker »
mysql> select * from Users;
| Id | Username | Password         | Language | Enabled | Stream | Events | Monitors | System | MonitorIds |
|  1 | admin    | 49fc982b75ac5d7a |          |       1 | View   | Edit   | Edit     | Edit   | NULL       |
1 row in set (0.00 sec)
How do I get the value of dbrow? I couldn't figure it out...
This also looks interesting, don't know if it means anything:
(gdb) break 321
Breakpoint 1 at 0x804af19: file zmu.cpp, line 321.
(gdb) run -d 0 -q -v -U admin -P xxxxxxxx
[New Thread 16384 (LWP 1296)]
[Switching to Thread 16384 (LWP 1296)]
Breakpoint 1, main (argc=134642259, argv=0xbffffd54) at zmu.cpp:321
321                             user = zmLoadUser( username, password );
(gdb) step
zmLoadUser (username=0x800 <Address 0x800 out of bounds>, password=0xbffffe75 "xxxxxxxx") at zm_user.cpp:108
108             char sql[BUFSIZ] = "";
zoneminder
Site Admin
Try 'x dbrow' or failing that 'p dbrow[0]', 'p dbrow[1]' etc
bparker
Post by bparker »
[Switching to Thread 16384 (LWP 1390)]
(gdb) x dbrow
No symbol "dbrow" in current context.
(gdb) p dbrow[0]
(gdb) p dbrow[1]
(gdb) up
#1  0x08060b3e in User (this=0xd1b1e48, dbrow=@0xbfffb81c) at stdlib.h:316
316     {
(gdb) x dbrow
0xd1b5de8:      0x696d6461
(gdb) p dbrow[0]
$1 = 0xd1b5de8 "admin"
(gdb) p dbrow[1]
$2 = 0xd1b5dee "49fc982b75ac5d7a"
(gdb) p dbrow[2]
$3 = 0xd1b5dff "2"
(gdb) p dbrow[3]
$4 = 0xd1b5e01 "3"
(gdb) p dbrow[4]
$5 = 0xd1b5e03 "3"
(gdb) p dbrow[5]
$6 = 0xd1b5e05 "3"
(gdb) p dbrow[6]
$7 = 0x0
(gdb) p dbrow[7]
$8 = 0xd1b5e07 ""
(gdb) p dbrow[8]
$9 = 0x696d6461 ""
(gdb) p dbrow[9]
$10 = 0x3934006e <Address 0x3934006e out of bounds>
(gdb)
bparker
Post by bparker »
anyone ever find a solution to this?
cordel
Post by cordel »
Have you tried the new release yet? Phil might have found the issue and made the changes in hte new release and forgot to post the findings. It's not hard to lose things like that on the forum. I've set up a bug tracker but still have to talk to Phil about it.
Cheers,
Cordel
zoneminder
Site Admin
I did find an issue relatively recently with uninitialised user data in zmu. This was fixed in 1.21.0 if not before. . I'd forgotten that anyone had mentioned a problem with it so it probably got wrapped up in other change. It's probably worth retrying this issue though on the newer version.
Phil
