When I specify a link that requires a redirect return is:
12/28/10 06:02:06.063556 zmc_m1[20346].INF-zmc.cpp/188 [Starting Capture]
12/28/10 06:02:06.273556 zmc_m1[20347].ERR-zm_rtsp.cpp/266 [Unexpected response code 302, text is 'Found']
12/28/10 06:02:17.783556 zmc_m1[20346].FAT-zm_remote_camera_rtsp.cpp/118 [No RTSP sources]
Follow HTTP Redirect
Just something quick to get you running.
I wrote this quickly without even testing it or trying to compile it, hopefully it works for you.
mastertheknife.
--- a/src/zm_rtsp.cpp
+++ b/src/zm_rtsp.cpp
@@ -201,6 +201,11 @@ int RtspThread::run()
std::string message;
std::string response;
+ bool torestart = false;
+ const char* locationheader;
+ char newhost[32];
+ char newpath[64];
+ char newport[8];
response.reserve( ZM_NETWORK_BUFSIZ );
@@ -216,6 +221,7 @@ int RtspThread::run()
if ( mMethod == RTP_RTSP_HTTP )
+ do {
if ( !mRtspSocket2.connect( mHost.c_str(), strtol( mPort.c_str(), NULL, 10 ) ) )
Fatal( "Unable to connect auxiliary RTSP/HTTP socket" );
//Select select( 0.25 );
@@ -260,9 +266,29 @@ int RtspThread::run()
Hexdump( ZM_DBG_ERR, response.data(), min(response.size(),16) );
return( -1 );
- if ( respCode != 200 )
+ /* Redirect */
+ if ( respCode == 301 || respCode == 302) {
+ locationheader = strstr(response.c_str(),"Location:");
+ if(locationheader == NULL) {
+ Error( "Unable to find new address in the redirect");
+ return ( -1 );
+ /* Check if a port is specified in the redirect */
+ if(strchr(locationheader,':') != NULL) {
+ sscanf(locationheader,"Location: http://%s:%s/%s",newhost,newport,newpath);
+ mPort = newport;
+ } else {
+ sscanf(locationheader,"Location: http://%s/%s",newhost,newpath);
+ mPort = "80";
+ mHost = newhost;
+ mPath = newpath;
+ torestart = true; /* Restart the loop to connect to the new host and path */
+ } else if (respCode != 200) {
Error( "Unexpected response code %d, text is '%s'", respCode, respText );
return( -1 );
@@ -280,6 +306,8 @@ int RtspThread::run()
Error( "Unable to send message '%s': %s", message.c_str(), strerror(errno) );
return( -1 );
+ while(torestart == true); /* Restart the loop if a redirect is found */
std::string localHost = "";
