Error when starting ZM (first time start) ...
vypre
Post by vypre »
Hi All,
I am starting ZM for the first time and I am getting this error:
Stopping ZoneMinder: DBI connect('database=zm;host=localhost.localdomain','root',...) failed: Client does not support authentication protocol requested by server; consider upgrading MySQL client at /usr/local/bin/zmpkg.pl line 64
Can't call method "prepare_cached" on an undefined value at /usr/local/bin/zmpkg.pl line 66.
BEGIN failed--compilation aborted at /usr/local/bin/zmpkg.pl line 74.
Any ideas as to what I am doing wrong?
Thanks.
vypre
Update ...
Post by vypre »
Sorry, I forgot a few details.
I am running version 1.20.1 of ZM, Fedora Core 3.
I have got everything else working (apache, php, mysql).
When I try and view http://localhost/zm/ I get the following error as well (similar to the command line error:
Warning: mysql_pconnect(): Client does not support authentication protocol requested by server; consider upgrading MySQL client in /usr/local/apache/htdocs/zm/zm_db.php on line 21
Could not connect to database: Client does not support authentication protocol requested by server; consider upgrading MySQL client
vypre
Additional ...
Post by vypre »
The only other strange thing that I had to do was (when installing MySQL from RPMs) was install a different shared library set.
So instead of installing:
MySQL-shared-4.1.9-0.i386.rpm
I had to install this:
MySQL-shared-compat-4.1.9-0.i386.rpm
Why does ZM use MySQL 3.x bits? (I think that is what it means)
vypre
Fixed ...
Post by vypre »
Hi all,
Well as is usually the case with these things I found the solution myself.
From what I can gather ZM uses an old authentication method for MySQL.
For this to work (well in my case anyway) I had to set the password for the old method.
All I did was go into a mysql command prompt and typed:
SET PASSWORD FOR'root'@'localhost' = OLD_PASSWORD('newpwd');
(notice the OLD_PASSWORD part, this was the difference)
Now I am able to get to the web page, next thing is to get the camera working! :D
Love the package, keep up the great work. :D
cordel
Post by cordel »
Just wondering if you edited /etc/zm.conf and gave it a user name and password?
Which version did you install from source or RPM?
If RPM did you run /usr/lib/zm/bin/zminit after updating the user and pass in the config?
