ZoneMinder and an AXIS 210 camera
shelluk
Post by shelluk »
Hi Guys
I am attempting to get an AXIS 210 camera working with ZoneMinder.
I have set the following:
General
Source type: Remote
Function: Monitor
Enabled: [tick]
Source
Remote Protocol: RTSP
Remote Method: RTP/RTSP/HTTP
Remote Host Name: username:password@ip.address
Remote Host Port: 80
Remote Host Path: /axis-cgi/mjpg/video.cgi
The IP is in red though on the ZoneMinder web page. Also if I use 'Probe' I get:
Unable to probe network cameras, status is '127'
If I use the above details to construct the full URL http://username:password@ip.address/axi ... /video.cgi then the video loads ok :)
Thank you
Shell
shelluk
Post by shelluk »
Hi
After some more reading of forums and log reading it looks like a shared memory issue. I have done some changes, and now got a black box instead of no box at all! :)
I do not think I've set the following correct though?
kernel.shmall = 300000
kernel.shmmax = 1200000000
Set up on Ubuntu:
RAM: 2GB
Video is: 640x480 at 24bit
I'll eventually want to record this too. Do I need to bring the size down?
Thanks for your help
Shell[/quote]
floam
Post by floam »
Does the HTTP protocol work?
shelluk
Post by shelluk »
Hi
I left all the settings as above but changed it to just HTTP. I get the same - a black box where I would expect the video stream.
Shell
shelluk
Post by shelluk »
Also the IP address under 'Source' on the main page is red.
dvarapala
Post by dvarapala »
Did you try
Remote Protocol: HTTP
Remote Method: Simple
AllenTuttle
Remote Host Path
Post by AllenTuttle »
I use HTTP Simple to get to Axis 210(a) cameras.
My remote host path is:
/axis-cgi/mjpg/video.cgi?resolution=320x240&req_fps=5
I also set capture width height to 320x240.
