[Solved] - ZM and Axis 210
LennyLurex
Post by LennyLurex »
I am having problems in getting a Axis 210 to work with ZM.
I have set up the camera in ZM to monitor, and the IP in the Monitor list is orange.
For some reason, when I click on the camera name, I am unable to see any image.
The remote host path is set to
/axis-cgi/jpg/image.cgi?resolution=320x240
Any help would be appreciated.
LennyLurex
Just looking at the logs, and it seems whenever I open the window to view the camera, i see in /var/log/apache2/error.log
[Tue Jan 18 06:27:03 2011] [error] [client 127.0.0.1] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 808, referer: http://localhost/zm/
[Tue Jan 18 06:27:03 2011] [error] [client 127.0.0.1] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 813, referer: http://localhost/zm/
[Tue Jan 18 06:27:03 2011] [error] [client 127.0.0.1] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 818, referer: http://localhost/zm/
[Tue Jan 18 06:27:03 2011] [error] [client 127.0.0.1] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 823, referer: http://localhost/zm/
[Tue Jan 18 06:27:03 2011] [error] [client 127.0.0.1] PHP Deprecated: Function ereg() is deprecated in /usr/share/zoneminder/includes/functions.php on line 828, referer: http://localhost/zm/
[Tue Jan 18 06:27:03 2011] [error] [client 127.0.0.1] script not found or unable to stat: /var/www/cgi-bin/nph-zms, referer: http://localhost/zm/?view=watch&mid=1
Could this be telling me something?
jani
Post by jani »
copy nph-zms into /var/www/cgi-bin/ and you will see the camera images
LennyLurex
Thank you Jani,
I did try that earlier, but must have copird to the wrong location. Now works as it should.
Thanks again for your help..
