After update Ubuntu 10.04LTS and 1.24.2 picture flicker
hudibras
Post by hudibras »
Seems to be wrong driver
[ 35.017666] bttv: driver version 0.9.18 loaded
[ 35.017669] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 35.017969] bttv: Bt8xx card found (0).
[ 35.017987] alloc irq_desc for 18 on node -1
[ 35.017989] alloc kstat_irqs on node -1
[ 35.017998] bttv 0000:00:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 35.018008] bttv0: Bt878 (rev 17) at 0000:00:0a.0, irq: 18, latency: 32, mmio: 0xf69fe000
[ 35.018029] bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
[ 35.018031] IRQ 18/bttv0: IRQF_DISABLED is not guaranteed on shared IRQs
[ 35.018068] bttv0: gpio: en=00000000, out=00000000 in=00f360ff [init]
Worked just fine ZM 1.23
USB camera looks good in Cheese, but also flickering in ZM 1.24
I have tried to move Conexeant to another PCI slot, the problem still persists.
wbclay
Post by wbclay »
Hudibras,
I just installed ZM 1.24.2 and bttv 0.9.18 for the first time and I'm also noticing flicker. I, too, am using a video card based on the BT878 (in may case, a Provideo PV-143). A couple questions about your previous installation, if the information is still available:
* What version of bttv was running before your OS upgrade? Could the problem be there?
* Have you tried regressing to ZM 1.23 on your new OS? If so, any improvement?
I'm continuing to experiment with ZM and bttv option settings, but so far, I have not noticed any change in the flicker (or much of anything else). I've also looked to see if there's a later version of bttv, but that's the version contained in the latest Linux Media source archive.
I'll post any discoveries and would appreciate hearing of anything you may learn.
Bill
hudibras
Post by hudibras »
wbclay wrote:Hudibras,
Bill
I don't recall the driver, but now it says booktree.
I don't think regressing is possible.
I have found a link there a zm1.24 runs the same board under Unbuntu 10.04LTS
I'm doing some research later today, there maybe a solution in the link. i'll send post it here if useable.
Max
