Prior to getting this card I had the hauppauge impactVCB card installed and working with 2 cameras after I followed the directions here
http://www.zoneminder.com/wiki/index.ph ... _ImpactVCB
but I was only getting 5 fps, so I bought the 4400r from camsecure. Currently all I see is a blue screen with a time stamp.
I tried the suggestions in this thread
http://www.zoneminder.com/forums/viewtopic.php?t=10429
as well as
http://www.zoneminder.com/wiki/index.php/Kodicom_4400r
with no luck.
sudo lspci -vv
04:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 64 (4000ns min, 10000ns max)
Interrupt: pin A routed to IRQ 21
Region 0: Memory at fdfff000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data <?>
Capabilities: [4c] Power Management version 2
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: bttv
Kernel modules: bttv
04:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Latency: 64 (1000ns min, 63750ns max)
Interrupt: pin A routed to IRQ 10
Region 0: Memory at fdffe000 (32-bit, prefetchable) [size=4K]
04:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Interrupt: pin A routed to IRQ 22
Region 0: Memory at fdffd000 (32-bit, prefetchable) [size=4K]
04:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Interrupt: pin A routed to IRQ 11
Region 0: Memory at fdffc000 (32-bit, prefetchable) [size=4K]
04:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Interrupt: pin A routed to IRQ 23
Region 0: Memory at fdffb000 (32-bit, prefetchable) [size=4K]
04:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Interrupt: pin A routed to IRQ 15
Region 0: Memory at fdffa000 (32-bit, prefetchable) [size=4K]
04:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Interrupt: pin A routed to IRQ 20
Region 0: Memory at fdff9000 (32-bit, prefetchable) [size=4K]
04:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Interrupt: pin A routed to IRQ 5
Region 0: Memory at fdff8000 (32-bit, prefetchable) [size=4K]
sudo dmesg | grep bttv
[ 10.565237] bttv: driver version 0.9.18 loaded
[ 10.565247] bttv: using 16 buffers with 2080k (520 pages) each for capture
[ 10.565981] bttv: Bt8xx card found (0).
[ 10.566042] bttv 0000:04:0c.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 10.566066] bttv0: Bt878 (rev 17) at 0000:04:0c.0, irq: 21, latency: 64, mmio: 0xfdfff000
[ 10.566112] bttv0: using: Kodicom 4400R (slave) [card=133,insmod option]
[ 10.566120] IRQ 21/bttv0: IRQF_DISABLED is not guaranteed on shared IRQs
[ 10.566183] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 10.566499] bttv0: tuner absent
[ 10.566904] bttv0: registered device video0
[ 10.567305] bttv0: registered device vbi0
[ 10.567339] bttv0: PLL: 28636363 => 35468950 ..
[ 10.604203] bttv: Bt8xx card found (1).
[ 10.604260] bttv 0000:04:0d.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 10.604283] bttv1: Bt878 (rev 17) at 0000:04:0d.0, irq: 22, latency: 64, mmio: 0xfdffd000
[ 10.604325] bttv1: using: Kodicom 4400R (master) [card=132,insmod option]
[ 10.604333] IRQ 22/bttv1: IRQF_DISABLED is not guaranteed on shared IRQs
[ 10.604399] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 10.605569] bttv1: tuner absent
[ 10.605767] bttv1: registered device video1
[ 10.605866] bttv1: registered device vbi1
[ 10.605898] bttv1: PLL: 28636363 => 35468950 .
[ 10.607984] bttv1: PLL: 28636363 => 35468950 .
[ 10.609525] bttv1: PLL: 28636363 => 35468950 .. ok
[ 19.137114] bttv0: PLL can sleep, using XTAL (28636363).
[ 42.796558] bttv: Bt8xx card found (2).
[ 42.796589] bttv 0000:04:0e.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[ 42.796609] bttv2: Bt878 (rev 17) at 0000:04:0e.0, irq: 23, latency: 64, mmio: 0xfdffb000
[ 42.796670] bttv2: using: Kodicom 4400R (slave) [card=133,insmod option]
[ 42.796678] IRQ 23/bttv2: IRQF_DISABLED is not guaranteed on shared IRQs
[ 42.796721] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 42.796836] bttv2: tuner absent
[ 42.796986] bttv2: registered device video2
[ 42.797059] bttv2: registered device vbi2
[ 42.797100] bttv2: PLL: 28636363 => 35468950 .
[ 42.798906] bttv2: PLL: 28636363 => 35468950 .
[ 42.799261] bttv2: PLL: 28636363 => 35468950 .. ok
[ 74.988549] bttv: Bt8xx card found (3).
[ 74.988599] bttv 0000:04:0f.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 74.988618] bttv3: Bt878 (rev 17) at 0000:04:0f.0, irq: 20, latency: 64, mmio: 0xfdff9000
[ 74.988690] bttv3: using: Kodicom 4400R (slave) [card=133,insmod option]
[ 74.988698] IRQ 20/bttv3: IRQF_DISABLED is not guaranteed on shared IRQs
[ 74.988755] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 74.988995] bttv3: tuner absent
[ 74.989275] bttv3: registered device video3
[ 74.989449] bttv3: registered device vbi3
[ 74.989487] bttv3: PLL: 28636363 => 35468950 .. ok
[ 482.531495] bttv1: PLL can sleep, using XTAL (28636363).
[ 503.437639] bttv2: PLL can sleep, using XTAL (28636363).
ls /dev/video* shows /dev/video0-3
I have a monitor setup with videoforlinux1, ntsc, yuyv, /dev/video0, channel 0. What am I doing wrong?
edit: I am running ubuntu 10.04
kodicom 4400r
I would play with your memory.
My 8 port Kodicom like DVR card looks like this:
07:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at e000f000 (32-bit, prefetchable) [size=4K]
Unknown small resource type 00, will not decode more.
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
07:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at e000d000 (32-bit, prefetchable) [size=4K]
07:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at e000b000 (32-bit, prefetchable) [size=4K]
07:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at e0009000 (32-bit, prefetchable) [size=4K]
07:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 02)
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Region 0: Memory at e0007000 (32-bit, prefetchable) [size=4K]
07:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Region 0: Memory at e0005000 (32-bit, prefetchable) [size=4K]
07:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at e0003000 (32-bit, prefetchable) [size=4K]
07:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Region 0: Memory at e0001000 (32-bit, prefetchable) [size=4K]
# ipcs
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x7a6d0001 3440640 www-data 700 3072952 2
0x7a6d0002 3473409 www-data 700 12289192 2
0x7a6d0003 3506178 www-data 700 12289192 2
0x7a6d0004 3538947 www-data 700 12289192 2
0x7a6d0005 3571716 www-data 700 12289192 2
0x7a6d0006 3604485 www-data 700 12289192 2
0x7a6d0007 3637254 www-data 700 18433352 2
0x7a6d0008 3670023 www-data 700 36865192 1
0x7a6d0009 3801096 www-data 700 36865192 1
0x7a6d000a 3735561 www-data 700 9216952 1
0x7a6d000b 3768330 www-data 700 36865192 1
------ Semaphore Arrays --------
key semid owner perms nsems
0x00000000 98304 www-data 600 1
top - 07:32:27 up 12 days, 17:35, 2 users, load average: 3.65, 3.80, 3.67
Tasks: 116 total, 3 running, 113 sleeping, 0 stopped, 0 zombie
Cpu(s): 81.4%us, 1.8%sy, 0.0%ni, 16.2%id, 0.0%wa, 0.0%hi, 0.6%si, 0.0%st
Mem: 3344808k total, 2943232k used, 401576k free, 176992k buffers
Swap: 9936892k total, 0k used, 9936892k free, 2362316k cached
