Hello all:
Let me start by saying that this setup worked perfectly fine under Ubuntu Intrepid and Zoneminder 1.23.
Yesterday I decided to wipe everything, clean install Maverick, and install Zoneminder 1.24 via Synaptics Package Manager.
Everything seems to have gone smoothly, except that the video seems to bleed between the channels. What I mean by this is that it almost seems like both channels are cycling together. Regardless of which monitor I click, I am getting either both channels showing the signal from one camera, or both channels showing the signal from another camera.
I have attached an image to specifically show my problem, and to show my settings.
Any ideas?
After upgrade Video "bleeding" from other channels
- zoneminder
- Site Admin
- Contact:
Re:
Hello . I am from Russia. I apologize for my English. I have the same problem with the card SDVR-1604 and a map SDVR-607d. Proposed an alternative you did not help.
Maybe the fact that the driver does not supports a this type of payment and should not continue to suffer?
Thanks in advance))
Maybe the problem is even in something?zoneminder wrote:Have a look at the Options->Config->V4L_MULTI_BUFFER and CAPTURES_PER_FRAME options and see if fiddlingwith those makes any difference.
Thanks in advance))
Re: After upgrade Video "bleeding" from other channels
Try setting captures_per_frame to 2 or more.
mastertheknife
mastertheknife
Kfir Itzhak.
