cambozola.jar location
barrydocks
Post by barrydocks »
where do I need to put this in order for streaming to work with IE?
christophe_y2k
Post by christophe_y2k »
i put the .jar file in web root directory, the same place where you can found your zoneminder index.php typically /var/www/zoneminder/htdocs
barrydocks
still struggling with this, I have zoneminder V 1.24.2 running on Ubuntu Server 10.04.2 32bit.
I have copied cambozola.jar to both the /var/www and /usr/share/zoneminder directories but still no streaming in IE ?? I get a refresh every 3 to 4 seconds?
Help? :cry:
insippo
Post by insippo »
IE is the 666 browser.Install ubuntu and use FF.
barrydocks
insippo wrote:IE is the 666 browser.Install ubuntu and use FF.
Installing ubuntu is not an option.
insippo
Post by insippo »
Google Chome not show video in zm but FF works ok
My mother tongue is not english.Sorry if I do not speak correctly.
mastertheknife
Post by mastertheknife »
barrydocks wrote:still struggling with this, I have zoneminder V 1.24.2 running on Ubuntu Server 10.04.2 32bit.
Help? :cry:
Have you enabled cambozola in your settings? And make sure your streaming type is jpeg and not mpeg.
Also, check if the cambozola.jar file is accessible by trying to download it by typing the link to your cambozola.jar in your web browser and trying to download it.
mastertheknife
barrydocks
mastertheknife wrote:Have you enabled cambozola in your settings?
That worked :oops:
