Installation error in CentOS 5.5
clipo
Post by clipo »
moo wrote:Ah, getting the dreadded mmap errors now! Have come across this with my last working build in the past so will crack on with fixing...however find it slightly odd that I wasn't experiencing this with the .2 install?
Clipo did you experience this error @ compile time by any chance, too?
configure: error: zm requires Sys::Mmap for mapped memory
Moo, Yes I did come across that error and a few more and solved them with the method described above,
To my knowledge there is still some thing broken inside the CentOS 5.5 release that causes the build process to be difficult and I'm convinced some functions of ZM are not working correct, it seem to be related to ffmpeg but I have tried to compile 0.5 from source and ended up with various errors.
If its of help to the admin I will recreate the problems and post detailed logs.
moo
Post by moo »
seems that way, be interesting to see your logs :)
fixed mmap but again still having issues with ffmpeg when doing make for zoneminder, will try a couple of different [ffmpeg] releases again :)
moo
Post by moo »
Ok, so the error looks different now, this is back to ffmpeg 0.6.1, which looked like a cleaner install than the latest version from their git repo.
make  all-recursive
make[1]: Entering directory `/ZoneMinder-1.24.3'
Making all in src
make[2]: Entering directory `/ZoneMinder-1.24.3/src'
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include   -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_mpeg.h:23,
                 from zm_stream.h:27,
                 from zm_event.h:39,
                 from zm_zone.h:27,
                 from zm_monitor.h:26,
                 from zmc.cpp:28:
zm_ffmpeg.h:33:2: error: #error "No location for avutils.h found"
zm_ffmpeg.h:40:2: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:47:2: error: #error "No location for avformat.h found"
zm_ffmpeg.h:55:2: error: #error "No location for swscale.h found"
zm_mpeg.h:43: error: use of enum âPixelFormatâ without previous declaration
zm_mpeg.h:44: error: ISO C++ forbids declaration of âAVOutputFormatâ with no type
zm_mpeg.h:44: error: expected â;â before â*â token
zm_mpeg.h:45: error: ISO C++ forbids declaration of âAVFormatContextâ with no type
zm_mpeg.h:45: error: expected â;â before â*â token
zm_mpeg.h:46: error: ISO C++ forbids declaration of âAVStreamâ with no type
zm_mpeg.h:46: error: expected â;â before â*â token
zm_mpeg.h:47: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_mpeg.h:47: error: expected â;â before â*â token
zm_mpeg.h:48: error: ISO C++ forbids declaration of âAVFrameâ with no type
zm_mpeg.h:48: error: expected â;â before â*â token
make[2]: *** [zmc.o] Error 1
make[2]: Leaving directory `/ZoneMinder-1.24.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/ZoneMinder-1.24.3'
make: *** [all] Error 2
im a network/IT bod, definitely no programer hehe, however does this look to you guys like it's a problem with swscale again? maybe I'm missing some more libs?
andywright
Post by andywright »
if it's any help to you guys trying to install on CentOS, this is a script I wrote that downloads and installs ZM and its pre-requisites. Works fine for me on Centos 5.5 32bit.
It also installs the files needed for the EyeZM iPhone client and h264 streaming - comment those out if you don't need em.
With 1.24.3 I have problems that I didn't see in 1.24.2, mostly things like missing events and status info in the monitor window. Would be interested if others are having these problems too.
Andy.
#!/bin/bash
rpm -Uhv http://apt.sw.be/redhat/el5/en/i386/rpm ... f.i386.rpm
yum -y install mysql mysql-server mysql-devel php php-gd php-mysql httpd gcc pcre-devel gd mod_ssl glib2-devel gcc-c++ ntp gnutls-devel ImageMagick perl-Archive-Tar perl-MIME-Lite perl-MIME-tools perl-Date-Manip perl-LWP-UserAgent-Determined perl-Sys-Mmap perl-PHP-Serialization perl-Device-SerialPort perl-Archive-Zip perl-Module-Load subversion git yasm netpbm netpbm-progs bzip2-devel nasm autoconf automake libtool
cd /root
wget http://www.zoneminder.com/fileadmin/dow ... bozola.jar
#svn co http://svn.zoneminder.com/svn/zm/trunk zm
wget http://www2.zoneminder.com/downloads/Zo ... 4.3.tar.gz
svn co http://libjpeg-turbo.svn.sourceforge.ne ... urbo/trunk libjpeg-turbo
wget http://www.eyezm.com/plugins/zm_xml_p2fs2_r3211.tar.gz
git clone git://git.videolan.org/x264.git
git clone git://git.gitorious.org/ffmpeg/ffmpeg-mt
cd ffmpeg-mt
git clone git://git.mplayerhq.hu/libswscale
#exit
echo
echo "libjpeg-turbo"
sleep 5
cd /root/libjpeg-turbo
autoreconf -fiv
./configure
make
make install prefix=/usr libdir=/usr/lib
echo
echo "x264"
sleep 5
cd /root/x264
./configure
make
make install
echo
echo "ffmpeg-mt"
sleep 5
cd /root/ffmpeg-mt
./configure --prefix=/usr --enable-gpl --enable-version3 --enable-nonfree --enable-postproc --enable-pthreads --enable-libx264 --enable-shared
make
make install
make install-libs
ldconfig
echo
echo "XML Plugin"
sleep 5
cd /root
tar zxvf zm_xml_p2fs2_r3211.tar.gz
cd zm_xml_p2fs2
bunzip2 httpsegmenter.tar.bz2
tar xvf httpsegmenter.tar
echo "Segmenter"
sleep 5
cd httpsegmenter
make
cp segmenter /usr/bin
echo "ZM - Expand"
sleep 5
cd /root
tar zxvf ZoneMinder-1.24.3.tar.gz
#cp /root/zm_xml_p2fs2/zmstreamer.1.24.2.patch /root/ZoneMinder-1.24.2
#cd /root/ZoneMinder-1.24.2
#echo
#echo "Patch ZM"
#sleep 5
#patch -p0 < ./zmstreamer.1.24.2.patch
echo
echo "ZM - ./configure ZM"
sleep 5
cd /root/ZoneMinder-1.24.3
./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin CXXFLAGS=-D__STDC_CONSTANT_MACROS --enable-mmap --sysconfdir=/etc/zm
make
make install
echo
echo "Install XML Plugin"
sleep 5
cd /root/zm_xml_p2fs2
(echo) | ./install
echo
echo "Create ZM DB"
sleep 5
service mysqld start
(echo "create database zm;") | mysql -u root
(echo "grant CREATE, INSERT, SELECT, DELETE, UPDATE on zm.* to zmuser@localhost;") | mysql -u root
(echo "SET PASSWORD FOR zmuser@localhost=PASSWORD('zmpass');") | mysql -u root
mysql -u root zm < db/zm_create.sql
cp scripts/zm /etc/init.d/
chmod +x /etc/init.d/zm
cp /root/cambozola.jar /var/www/html/zm/
mv /usr/local/bin/zmstreamer /usr/bin
ln -s /usr/bin/ffmpeg /usr/local/bin/ffmpeg
chkconfig acpid off
chkconfig apmd off
chkconfig auditd off
chkconfig autofs off
chkconfig avahi-daemon off
chkconfig bluetooth off
chkconfig cpuspeed off
chkconfig cups off
chkconfig gpm off
chkconfig haldaemon off
chkconfig hidd off
chkconfig httpd on
chkconfig ip6tables off
chkconfig iptables off
chkconfig kudzu off
chkconfig mcstrans off
chkconfig mdmonitor off
chkconfig microcode_ctl on
chkconfig mysqld on
chkconfig netfs off
chkconfig nfs off
chkconfig nfslock off
chkconfig ntpd on
chkconfig pcscd off
chkconfig portmap off
chkconfig rawdevices off
chkconfig restorecond off
chkconfig rpcgssd off
chkconfig rpcidmapd off
chkconfig rpcsvcgssd off
chkconfig sendmail on
chkconfig smartd off
chkconfig xfs off
chkconfig yum-updatesd off
chkconfig zm on
echo
echo "Now Reboot!"
moo
Post by moo »
@andywright
thats handy! I seem to have a problem with sql after running your script, however, it appears the zm.Conf "table" is missing (the web FE reporting this..)
Did you come across this yourself?
moo
Post by moo »
ignore that lol, friday syndrome :P
fixed! so created db all good, that script is legendary, thanks!!!!!! :D
Sorry for chiming in late. Thought I'd share my experience as I have been running Zoneminder on 64bit CentOS for over a year now. I have been keeping up with the latest Zoneminder svn so I know the steps below are still relevant.
The following works flawlessly for me:
- Get ffmpeg SVN-r21847
- configure ffmpeg with the following options:
./configure \
--enable-gpl \
--enable-shared \
--enable-pthreads \
--enable-nonfree \
--cpu=opteron \
--extra-cflags="-O3 -march=opteron -mtune=opteron"
- make, make install, make install-libs
- Now get the latest zoneminder from svn.
- configure zoneminder with the following options:
./configure \
--with-webdir=/var/www/html/zm \
--with-cgidir=/var/www/cgi-bin \
--with-webuser=apache \
--with-webgroup=apache \
--with-libarch=lib64 \
--with-ffmpeg=/usr/local \
--with-mysql=/usr \
--enable-mmap=yes \
--with-extralibs="-L/usr/lib64 -L/usr/lib64/mysql" \
CFLAGS="-g -O3 -march=opteron -mtune=opteron" \
CXXFLAGS="-g -O3 -march=opteron -mtune=opteron"
- done!
I did not have to edit any of the source code to get it to compile. You will need to delete the cpu specific stuff if you do not have an opteron cpu.
