My zoneminder 1.23.3 is functioning correctly. But I get lots of problem when accessing zm through browser.
Below are some of the strange behaviors:
* The web access http://localhost/zm loads OK and I can view the events normally. After accessing the zm web ( clicking, delete, replay) for sometime then the access gets freeze. To solve this freezing, I have to close the browser and start it again. And even sometime I need to restart httpd and Zoneminder.
Here are the log files:
1) apache error log
root@localhost 8]# tail -f /var/log/httpd/error_log
[Fri Nov 14 12:49:41 2008] [notice] Digest: done
[Fri Nov 14 12:49:41 2008] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
[Fri Nov 14 14:25:30 2008] [error] [client 127.0.0.1] File does not exist: /var/www/html/favicon.ico
[Fri Nov 14 14:30:11 2008] [warn] [client 127.0.0.1] Timeout waiting for output from CGI script /var/www/cgi-bin/nph-zms, referer: http://localhost/zm/index.php?view=watc ... 0&control=
[Fri Nov 14 14:30:11 2008] [warn] [client x.x.x.46] Timeout waiting for output from CGI script /var/www/cgi-bin/nph-zms, referer: http://10.42.40.138/zm/index.php?view=w ... 0&control=
[Fri Nov 14 14:30:20 2008] [notice] caught SIGTERM, shutting down
[Fri Nov 14 14:30:20 2008] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Nov 14 14:30:20 2008] [notice] Digest: generating secret for digest authentication ...
[Fri Nov 14 14:30:20 2008] [notice] Digest: done
[Fri Nov 14 14:30:20 2008] [notice] Apache/2.2.3 (CentOS) configured -- resuming normal operations
2) zm log:
After deleting some events ( not all)
Nov 14 14:27:36 localhost zms[10106]: ERR [Can't open /var/www/html/zm/events/8/1101/024-capture.jpg: No such file or directory]
Nov 14 14:27:37 localhost zms[10055]: ERR [Can't open /var/www/html/zm/events/8/1092/024-capture.jpg: No such file or directory]
Nov 14 14:27:37 localhost zms[10085]: ERR [Can't open /var/www/html/zm/events/8/1097/024-capture.jpg: No such file or directory]
Nov 14 14:27:37 localhost zms[10110]: ERR [Can't open /var/www/html/zm/events/8/1102/024-capture.jpg: No such file or directory]
Nov 14 14:27:37 localhost zms[10058]: ERR [Can't open /var/www/html/zm/events/8/1093/024-capture.jpg: No such file or directory]
Nov 14 14:27:38 localhost zms[10089]: ERR [Can't open /var/www/html/zm/events/8/1098/024-capture.jpg: No such file or directory]
Nov 14 14:29:56 localhost zms[10103]: ERR [Can't open /var/www/html/zm/events/8/1100/024-capture.jpg: No such file or directory]
Nov 14 14:29:56 localhost zms[10053]: ERR [Can't open /var/www/html/zm/events/8/1091/023-capture.jpg: No such file or directory]
[root@localhost 8]# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
[root@localhost 8]# tail -f /var/log/messages
Nov 14 14:30:20 localhost zms[10103]: INF [Got signal (Terminated), exiting]
Nov 14 14:30:20 localhost zms[10076]: INF [Got signal (Terminated), exiting]
Nov 14 14:30:20 localhost zms[10030]: INF [Got signal (Terminated), exiting]
Nov 14 14:30:20 localhost zms[10053]: INF [Got signal (Terminated), exiting]
Nov 14 14:30:20 localhost zms[10072]: INF [Got signal (Terminated), exiting]
Nov 14 14:30:20 localhost zms[10092]: INF [Got signal (Terminated), exiting]
Nov 14 14:30:20 localhost zms[10055]: INF [Got signal (Terminated), exiting]
Nov 14 14:30:20 localhost zms[10089]: INF [Got signal (Terminated), exiting]
What is the problem?
Paras.
Access problem
Is a problem with apache, I think
I have the same problem. After several click and camera views, I can't get any more information from the apache server. I deduced it was an apache problem, because of the Apache errors (caught SIGTERM). When I restart apache (sudo /etc/init.d/apache2 restart, it works again for a bunch of web requests, then stops.
I still haven't found the solution, but this information might help someone else.
me too
I am having same exact symptoms and errors.
Additionally, I see this sometimes:
[Thu Sep 17 00:19:37 2009] [error] [client 192.168.1.102] array (\n 0 => \n array (\n 'file' => '/usr/share/zoneminder/ajax/stream.php',\n 'line' => 51,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-786081s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/usr/share/zoneminder/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/usr/share/zoneminder/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://192.168.1.11/zm/?view=event&eid= ... c=1&page=1
Hath thou light to be shed?
