I don't get any images from xawtv or zm...
I tested the system hardware with windows xp and it worked.
Attempting ubuntu-zoneminder system.
Abit IP35-Pro motherboard
EVGA Nvidia 8600GTS video card
PV-183 8 camer capture card
TP-WIR550 Camera
Ubuntu 7.1 Server 2.6.22-14-server
Installed zoneminder 1.22.3 from "install package" from ubuntu.
Installed xawtv to test cameras.
Edited /etc/modprobe.d/options
options bttv card=98,98,98,98,98,98,98,98
dmesg | grep bttv
[ 30.566088] bttv: driver version 0.9.17 loaded
[ 30.566090] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 30.566113] bttv: Bt8xx card found (0).
[ 30.566145] bttv0: Bt878 (rev 17) at 0000:05:04.0, irq: 21, latency: 16, mmio: 0xfdaff000
[ 30.566151] bttv0: subsystem: 1830:1540 (UNKNOWN)
[ 30.566153] bttv0: using: ProVideo PV150 [card=98,insmod option]
[ 30.566176] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.566438] bttv0: using tuner=-1
[ 30.566439] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.567233] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.567844] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[ 30.568318] bttv0: registered device video0
[ 30.568328] bttv0: registered device vbi0
[ 30.568352] bttv0: PLL: 28636363 => 35468950 .. ok
[ 30.602337] bttv: Bt8xx card found (1).
[ 30.602367] bttv1: Bt878 (rev 17) at 0000:05:05.0, irq: 22, latency: 16, mmio: 0xfdafd000
[ 30.602373] bttv1: subsystem: 1831:1540 (UNKNOWN)
[ 30.602376] bttv1: using: ProVideo PV150 [card=98,insmod option]
[ 30.602399] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.602658] bttv1: using tuner=-1
[ 30.602660] bttv1: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.611324] bttv1: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.611792] bttv1: i2c: checking for TDA9887 @ 0x86... not found
[ 30.612265] bttv1: registered device video1
[ 30.612274] bttv1: registered device vbi1
[ 30.612298] bttv1: PLL: 28636363 => 35468950 .. ok
[ 30.642266] bttv: Bt8xx card found (2).
[ 30.642296] bttv2: Bt878 (rev 17) at 0000:05:06.0, irq: 19, latency: 16, mmio: 0xfdafb000
[ 30.642303] bttv2: subsystem: 1832:1540 (UNKNOWN)
[ 30.642307] bttv2: using: ProVideo PV150 [card=98,insmod option]
[ 30.642332] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.642604] bttv2: using tuner=-1
[ 30.642605] bttv2: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.643126] bttv2: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.643588] bttv2: i2c: checking for TDA9887 @ 0x86... not found
[ 30.644060] bttv2: registered device video2
[ 30.644069] bttv2: registered device vbi2
[ 30.644092] bttv2: PLL: 28636363 => 35468950 .. ok
[ 30.682189] bttv: Bt8xx card found (3).
[ 30.682216] bttv3: Bt878 (rev 17) at 0000:05:07.0, irq: 18, latency: 16, mmio: 0xfdaf9000
[ 30.682223] bttv3: subsystem: 1833:1540 (UNKNOWN)
[ 30.682227] bttv3: using: ProVideo PV150 [card=98,insmod option]
[ 30.682249] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.682517] bttv3: using tuner=-1
[ 30.682518] bttv3: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.683045] bttv3: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.683547] bttv3: i2c: checking for TDA9887 @ 0x86... not found
[ 30.684018] bttv3: registered device video3
[ 30.684029] bttv3: registered device vbi3
[ 30.684052] bttv3: PLL: 28636363 => 35468950 .<6>ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 22 (level, low) -> IRQ 19
[ 30.722112] bttv: Bt8xx card found (4).
[ 30.722139] bttv4: Bt878 (rev 17) at 0000:05:08.0, irq: 21, latency: 16, mmio: 0xfdaf7000
[ 30.722146] bttv4: subsystem: 1837:1540 (UNKNOWN)
[ 30.722150] bttv4: using: ProVideo PV150 [card=98,insmod option]
[ 30.722172] bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.722442] bttv4: using tuner=-1
[ 30.722443] bttv4: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.722979] bttv4: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.723440] bttv4: i2c: checking for TDA9887 @ 0x86... not found
[ 30.723912] bttv4: registered device video4
[ 30.723920] bttv4: registered device vbi4
[ 30.723944] bttv4: PLL: 28636363 => 35468950 .. ok
[ 30.762036] bttv: Bt8xx card found (5).
[ 30.762063] bttv5: Bt878 (rev 17) at 0000:05:09.0, irq: 22, latency: 16, mmio: 0xfdaf5000
[ 30.762070] bttv5: subsystem: 1834:1540 (UNKNOWN)
[ 30.762074] bttv5: using: ProVideo PV150 [card=98,insmod option]
[ 30.762101] bttv5: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.762366] bttv5: using tuner=-1
[ 30.762367] bttv5: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.762908] bttv5: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.763369] bttv5: i2c: checking for TDA9887 @ 0x86... not found
[ 30.763840] bttv5: registered device video5
[ 30.763850] bttv5: registered device vbi5
[ 30.763873] bttv5: PLL: 28636363 => 35468950 .. ok
[ 30.801962] bttv: Bt8xx card found (6).
[ 30.801990] bttv6: Bt878 (rev 17) at 0000:05:0a.0, irq: 19, latency: 16, mmio: 0xfdaf3000
[ 30.801998] bttv6: subsystem: 1835:1540 (UNKNOWN)
[ 30.802001] bttv6: using: ProVideo PV150 [card=98,insmod option]
[ 30.802023] bttv6: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.802291] bttv6: using tuner=-1
[ 30.802292] bttv6: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.802844] bttv6: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.803305] bttv6: i2c: checking for TDA9887 @ 0x86... not found
[ 30.803776] bttv6: registered device video6
[ 30.803785] bttv6: registered device vbi6
[ 30.803809] bttv6: PLL: 28636363 => 35468950 .. ok
[ 30.841885] bttv: Bt8xx card found (7).
[ 30.841917] bttv7: Bt878 (rev 17) at 0000:05:0b.0, irq: 18, latency: 16, mmio: 0xfdaf1000
[ 30.841925] bttv7: subsystem: 1836:1540 (UNKNOWN)
[ 30.841928] bttv7: using: ProVideo PV150 [card=98,insmod option]
[ 30.841950] bttv7: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 30.842217] bttv7: using tuner=-1
[ 30.842218] bttv7: i2c: checking for TDA9875 @ 0xb0... not found
[ 30.842782] bttv7: i2c: checking for TDA7432 @ 0x8a... not found
[ 30.843243] bttv7: i2c: checking for TDA9887 @ 0x86... not found
[ 30.843715] bttv7: registered device video7
[ 30.843724] bttv7: registered device vbi7
[ 30.843748] bttv7: PLL: 28636363 => 35468950 .. ok
[ 183.110768] bttv0: PLL can sleep, using XTAL (28636363).
[ 420.730042] bttv0: PLL: 28636363 => 35468950 .. ok
[ 431.153846] bttv0: PLL can sleep, using XTAL (28636363).
[ 457.664594] bttv1: PLL can sleep, using XTAL (28636363).
[ 481.649697] bttv2: PLL can sleep, using XTAL (28636363).
[ 507.743515] bttv3: PLL can sleep, using XTAL (28636363).
[ 533.130881] bttv4: PLL can sleep, using XTAL (28636363).
[ 547.559261] bttv4: PLL: 28636363 => 35468950 .. ok
xawtv -hwscan
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.22-14-server)
looking for available devices
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video (ProVideo PV150)
flags: overlay capture
/dev/video1: OK [ -device /dev/video1 ]
type : v4l2
/dev/video2: OK [ -device /dev/video2 ]
type : v4l2
/dev/video3: OK [ -device /dev/video3 ]
type : v4l2
xawtv -device /dev/video0
xinerama 0: 1680x1050+0+0
WARNING: No DGA support available for this display.
WARNING: couldn't find framebuffer base address, try manual
configuration ("v4l-conf -a <addr>")
Warning: Cannot convert string "-*-ledfixed-medium-r-*--39-*-*-*-c-*-*-*" to type FontStruct
ioctl: VIDIOC_OVERLAY(int=1): Invalid argument
[SOLVED] No Images in ZM or XAWTV
Last edited by digitalmasters on Sun Jun 22, 2008 9:27 pm, edited 1 time in total.
XAWTV working...not zoneminder
Have XAWTV working with camer and card.
When I setup a monitor in zoneminder, I don't get an image
Ideas?
zmu -d /dev/video4 -q -v
Video Capabilities
Name: BT878 video (ProVideo PV150)
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 2
Audio Channels: 0
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 7 - YUV422 capture
Colour Depth: 16
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Ideas?
Video Capabilities
Type: 171
Can capture
Can tune
Can clip
Scalable
Video Channels: 2
Audio Channels: 0
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Colour Depth: 16
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
no dga
In addition, to get xawtv to work I had to use...
xawtv -nodga -device /dev/video4
log messages
Jun 19 09:15:53 CNTR-3 zmdc[6418]: INF ['zmc -d /dev/video4' started at 08/06/19 09:15:53]
Jun 19 09:15:53 CNTR-3 zmdc[5324]: INF ['zmc -d /dev/video4' starting at 08/06/19 09:15:53, pid = 6418]
Jun 19 09:15:53 CNTR-3 zmwatch[5353]: INF ['zmc -d /dev/video4' starting at 08/06/19 09:15:53, pid = 6418]
Jun 19 09:15:53 CNTR-3 zmc_dvideo4[6418]: INF [Debug Level = 0, Debug Log = <none>]
Jun 19 09:16:03 CNTR-3 zmwatch[5353]: INF [Restarting capture daemon for Cam4, shared memory not valid]
How did you install? is zmfix working correctly? Post the result of;
ls /dev/vi* -lah
Working
Have it working now.
If run xawtv then zoneminder...I don't get any images in zoneminder.
However, if I do a reboot and run zoneminder without running xawtv
then I do get images.
