zmaudit.pl problem, solution
weyrick
Post by weyrick »
i had a problem with zmaudit.pl not cleaning up orphaned events properly. turned out to be that my monitor's had spaces in the names, and in zmaudit where it calls "rm -rf .." it wasn't quoting the path name so it was failing because of the space.
i fixed it by changing the rm command to have a quoted path. alternatively, if monitor names shouldn't have spaces, this should be checked at monitor creation.
shannon
zoneminder
Site Admin
Re: zmaudit.pl problem, solution
Post by zoneminder »
Hi Shannon,
Thanks for pointing this out, I'll apply the same fix to my source tree. I think there are one or two other issues with monitor names with spaces in them so while they aren't exactly forbidden they aren't recommended at present.
Phil,
