I was having issues on a cloudy day with a massive number of 1-10 alarm frame count 2 second videos being recorded (around 1000 an hour). I searched around and found someone who said changing the Alarm Frame Count to around 16 would get rid of this issue, so I did that and it fixed the problem.
Now however I have a time continuity issue. The server records all the events fine but they jump back in time. This causes them not to play back correctly in the Event Viewer window. I can export them fine however, when I watch the event I see someone walking in the frame, then they jump back and walk the same path they just did and then the video finishes correctly. I set the alarm frame count to different values and still have this issue unless it is set to 1 (setting it to 1 causes it to work perfectly fine).
This also causes an error in my httpd log when I try to view the event. I am also either forced to close my browser or restart the httpd service to be able to open any ZM webpage (all pages outside the ZM directory on the server work fine with out restarting browser or service).
I wonder if it is an issue with my buffer settings, but I could not find anything on the forum about this issue.
Here is my setup:
CentOS 5.5
ZoneMinder v1.24.2
Source Type: Ffmpeg
Image Buffer Size: 40
Warmup Frames: 25
Pre Event Image Count: 35
Post Event Image Count: 35
Stream Replay Image Buffer: 1000
Alarm Frame Count: 16
Here is my Apache error:
[Tue Jul 27 09:09:24 2010] [error] [client client] array (\n 0 => \n array (\n 'file' => '/var/www/html/zm/ajax/stream.php',\n 'line' => 55,\n 'function' => 'ajaxError',\n 'args' => \n array (\n 0 => 'socket_sendto( /tmp/zms-796558s.sock ) failed: No such file or directory',\n ),\n ),\n 1 => \n array (\n 'file' => '/var/www/html/zm/index.php',\n 'line' => 116,\n 'args' => \n array (\n 0 => '/var/www/html/zm/ajax/stream.php',\n ),\n 'function' => 'require_once',\n ),\n), referer: http://server/zm/index.php?view=event&eid=20069&filter[terms][0][attr]=MonitorId&filter[terms][0][op]=%3D&filter[terms][0][val]=2&sort_field=StartTime&sort_asc=1&page=1
