Date/Time/Camera Stamp Location
Ruler
Post by Ruler »
I was wondering if the location of the camera ID and date/time information that's captured with each frame can be moved by a configuration option. I've looked through the options and can't see it - am I missing something or is it always in the upper-left corner?
If it's permanent, this would be a nice addition to specify where to put it (and the size of the font if possible).
zoneminder
Site Admin
Post by zoneminder »
It's in the 'timestamps' tab of the monitor configuration. If you want it at the bottom of the frame don't forget to subtract 8 pixels from the height of your window or it will overlap the bottom and nasty things will happen.
Phil
Ruler
Post by Ruler »
Thanks Phil.
Sorry for bothering you with it - I should've seen that. I was looking in the global options, it never occurred to me to look in the per-camera settings. (Which is where this correctly belongs - I didn't spend enough time actually thinking to realize this before spending an hour looking for the option in the wrong places.)
Thanks again for the help and the heads-up with subtracting 8 from the height of the frame.
