I'm using ZoneMinder v1.24.2 on Ubuntu 10.10 x86_64.
I've got a problem with image shown in ZoneMinder: it jumps and triggers the alarm... hard to explain, so a sample available on that URL: http://docs.legeox.net/photos/011-analyse.jpg
I've tried to change the image ratio, but the problem is remaining.
I'm using a Microsoft Lifecam HD5000. The video don't have this problem using guvcview, xawtv or camorama.
Have you an idea ? Could you help me ?
Thanks in advance
legeoX[/url]
ZoneMinder, Image jumps (false alarms)
Re: ZoneMinder, Image jumps (false alarms)
I always have this problem. No solution found yet.
I had jumping problems with a card with the TechWell chip, but looks like your cam is USB right??? what I did to eliminate false alarms was to increment "Alarm Frame Count" and/or "Overload Frame Ignore Count" those two can help you eliminate alot of false alarms, even clouds (some)...
Thank you for your answer. Yes this cam is connected on a USB port.
I'm currently trying your solution to increase "Alarm Frame Count".
Where do you find the option "Overload Frame Ignore Count" ?
Thanks for help
Thanks for help
On the Zone setup window!!!
I've doubled checked the setup window and I've not found that option with that name.
After a test period, I confirm that the solution you tell me works fine (the image always jump but no more false alarms !)
Thank you !
Thank you !
It is located where you setup the Zone, where the coordinates of the zone is defined!!!
That time, ok I found it !
Thank you, I keep that in mind !
