Cannot Login To ZoneMinder Interface
alteredstate
Post by alteredstate »
Ok, I'm going to be the comic relief for this post but I cannot for the life of me login to the ZoneMinder Interface. I enabled this feature thinking it was my system username and password and then closed my web browser...guess I was wrong. Do I need to create a MySQL username and password? I thought this might be the case because I found this under the Ubuntu Installation tutorial (I'm using Ubuntu 10.04 Desktop):
# sudo mysql -u root -p < /usr/share/zoneminder/db/zm_create.sql
# mysql -u root -p (this brings you into a mysql shell)
# > grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
# > flush privileges;
# > quit (this exits the mysql shell)
I'm sure this is an easy fix but I'm not familiar with MySQL, Apache or ZoneMinder; I'm still trying to teach myself how these three systems work together.
PacoLM
Re: Cannot Login To ZoneMinder Interface
Post by PacoLM »
Did you change the settings as explained here:
http://www.zoneminder.com/wiki/index.ph ... _interface
Mainly look the section 'Define the web address of the ZoneMinder interface'.
Hope it helps,
PacoLM
alteredstate
PacoLM wrote:Hi,
Hope it helps,
PacoLM
That did it, thank you! I guess I need to read the Ubuntu 9.04 tutorial instead of the 10.04.
