1.24.2 doesnt support the bt878 controller I have been using for years with Zoneminder, I was considering reverting to 1.23 where it works perfectly? Can I go back to 1.23 without a fresh install or does someone have a suggestion on why my card which worked on all previous versions doesnt work now?
any help would be GREATLY appreciated
http://www.zoneminder.com/forums/viewtopic.php?t=17317
here is my card:
03:08.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (
rev 11)
03:08.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11
03:09.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (
rev 11)
03:09.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11
03:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (
rev 11)
03:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11
03:0b.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (
rev 11)
03:0b.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11
Can I back date to 1.23 from 1.24?
Re: Can I back date to 1.23 from 1.24?
Card should work, without problems. Please post your source settings for monitor. If I remember correctly I had to switch palette to BGR24 from RGB24 after upgrade...
