PTZ physical connection
racelife
Post by racelife »
I've been looking around and seen lots of info on scripts to control ptz cameras but how is the physical connection made? serial port? I have a friend with a camera he will let me borrow until I can afford one the specs are:
Communication system
RS485 bus control
Communication Protocol
Pelco-D / Pelco-P (optional)
Baud Rate
1200/2400/4800/9600/19200bps (adjustable)
clipo
Re: PTZ physical connection
Post by clipo »
You have already listed how it is connected in your description,
RS485
Google is your friend....
http://en.wikipedia.org/wiki/EIA-485
racelife
Post by racelife »
is there an RS485 connection on most motherboards? or is it rs485 protocol on a serial port? or will I use a usb to rs485 adapter?
clipo
Post by clipo »
Only some industrial PCs have RS485 on the motherboard, 99% of other computers require an expansion card to have it and I've never seen a USB to RS485 converter but that's not to say one dose not exist.
Once again Google is your friend
http://www.ebuyer.com/product/224157?ut ... m=products
racelife
Post by racelife »
I found the most economical solution is a rs232 to rs485 adapter to convert the serial port to rs485.
