First, sorry for my english, I'm from Poland.
Second, thanks for people who made this software, great job.
My question is, is there any way to calculate how many RAM memory do I need? For example if I know that my system will be 6 IP cams at 640x480 resolution @6fps with motion detection. I know I can run it and try, but better way is to know it before
Second question is the same for CPU.
I hope I say it cleary what i need to know, Thanks
How to calculate RAM
Re: How to calculate RAM
Are you talking about RAM or shared memory?. If you need some help in calculate your shared memory, take this script, that is a modified version of the script the user Pada (credits to him), that only calculates the values for shared memory:
Hope it helps,
PacoLM
#!/bin/sh
# Copyright (C) 2010 Chris "Pada" Kistner
# Modified by PacoLM to check only shared memory settings
# NOTE: -f you find errors, check that coreutils are installed, if not, run the command below
# apt-get -y install coreutils bc
echo "--- Checking memory setting..."
page_size=$(getconf PAGE_SIZE)
mem_bytes=$(awk '/MemTotal:/ { printf "%0.f",$2 * 1024}' /proc/meminfo)
mb=1048576
mem_bytes_mb=$(expr $mem_bytes / $mb)
shmmax=$(echo "$mem_bytes * 0.90" | bc | cut -f 1 -d '.')
shmmax_mb=$(expr $shmmax / $mb)
shmall=$(expr $mem_bytes / $page_size)
shmmax_cur=$(sysctl -n kernel.shmmax)
shmmax_cur_mb=$(expr $shmmax_cur / $mb)
shmall_cur=$(sysctl -n kernel.shmall)
echo "-- Total memory = $mem_bytes B = $mem_bytes_mb MB"
echo "-- Page size = $page_size B"
echo "-- Current kernel.shmmax = $shmmax_cur B = $shmmax_cur_mb MB"
echo "-- Current kernel.shmall = $shmall_cur pages"
if [ "$shmmax" -eq "$shmmax_cur" ] && [ "$shmall" -eq "$shmall_cur" ]; then
echo "-- Recommended shm values already set"
else
echo "-- Recommended: kernel.shmmax = $shmmax B = $shmmax_mb MB"
echo "-- Recommended: kernel.shmmall = $shmall pages"
fi
# Done
echo "--- Done."
PacoLM
Thanks for answer,
I read about shared memory calculating before, but I mean hardware RAM size and CPU freq.
Right now I'm testing ZM on some older machine with one 640x480 cheap cam and it works fine, but hardware specification is low and CPU is overload sometimes, specialy on motion detect.
The target for me is to make good platform for home ZM server with maybe 6 or 7 1,3Mpix cams and I want to know how to calculate the size and freq of parts I ask.
I dont how to say it better way
