Can anyone help me with this camera?
i installed correctly zm on my ubuntu, the problem is to find the remote path of the mjpg streaming.
looking into the canon developer's kit documentation, i found the address for the single shot (for example 192.168.0.50/-wvwhttp-01/getoneshot)
but nothing about the video stream.
so, if i write this string into the web browser i can see the last jpg shot of the camera.
i tried to use this address to configure zm,but it doesen't work, i get only a black square.
Canon vb-c50i
Re: Canon vb-c50i
solved video for canon vb-c50i and canon vb-c60.
now i try to configure ptz then i will put the howto in the forum area
special thanks to mastertheknife on the irc channel
Re: Canon vb-c50i
Your welcome.
It would have been useful to others if you posted the URLs for the MJPEG stream. here they are:
PAL version:
http://host:port/-wvhttp-01-/getoneshot?frame_count=no_limit&image_size=768x576
http://host:port/-wvhttp-01-/getoneshot?frame_count=no_limit&image_size=384x288
NTSC version:
http://host:port/-wvhttp-01-/getoneshot?frame_count=no_limit&image_size=640x480
http://host:port/-wvhttp-01-/getoneshot?frame_count=no_limit&image_size=320x240
mastertheknife
PAL version:
NTSC version:
mastertheknife
Kfir Itzhak.
