No Access To Source Tab
smilliken
Post by smilliken »
I just installed Zoneminder thru synaptic in Mepis 11(Debian based). I'm trying to get 2 IP wireless cameras working. I had one of the cameras working several months ago when playing with Zoneminder to see if the camera would work. It does.
Now when I go to "add new monitor", I can only enter information on the "general" tab. All of the other tabs are not accessible. See attached image.
This is probably a simple fix and maybe there is something not set up right.
Any and all help much appreciated.
Add Monitor Window
Add Monitor Window
Simply Mepis 11 Zoneminder 1.24.2-9
Without walls.....Who needs Windows!
PacoLM
Re: No Access To Source Tab
Post by PacoLM »
I had the same problem, run apt-get upgrade, followed by apt-get update. I believe that some dependencies of php are not updated.
Hope it helps, post results.
PacoLM
smilliken
Post by smilliken »
Thanks, gave that a whirl and same results.
I was wondering if it had something to do with the database set up.
PacoLM
Post by PacoLM »
I still think that you have the same problem as I had, so you need to upgrade your system. Check that the repositories in your sources.list match the version you have installed.
PacoLM
smilliken
Post by smilliken »
Which dependencies are used by zonemider, in regards to the php/mysql packages?
All of the repos are checked, reloaded and nothing shows up as upgradable.
PacoLM
Post by PacoLM »
I can't recall exactly which was the dependency I had to upgrade, but I believe was something related with PHP or python
Could you post your versions, so we could compare?.
Add this repository to your /etc/apt/sources.list -> deb http://ftp.de.debian.org/debian sid main, try again to apt-get update, then apt-get upgrade.
Find out the dependencies here : http://packages.debian.org/unstable/net/zoneminder
These are some of mine:
# php --version -> PHP 5.3.6-6 with Suhosin-Patch (cli) (built: Mar 31 2011 19:51:41)
# perl --version -> v5.10.1 (*) built for arm-linux-gnueabi-thread-multi
# python --version -> Python 2.6.6
# apache2 -V -> Server version: Apache/2.2.17 (Debian)
Let's check those and continue with the list in the previous link.
Hope it helps,
PacoLM
smilliken
Post by smilliken »
OK, I Mepis 11 uses Debian squeeze repos. I will add the sid repo and see what happens adn get back to the forum.
smilliken
Post by smilliken »
PacoLM wrote:I can't recall exactly which was the dependency I had to upgrade, but I believe was something related with PHP or python
Hope it helps,
PacoLM
I did a clean install of Mepis 11 and then re-installed zoneminder and hte dependencies, plus all of the other packages as per the wiki. still the same problem.
I upgraded the packages listed above and have these versions.
Apach2 - ver 2.2.17-3
php5 - ver 5.3.6-8
perl - ver 5.10.1-19
python - ver 2.6.6-14
Also upgrade zoneminder ver 1.24.2-8 to 1.24.2-9
The results is the same.
smilliken
Post by smilliken »
Been thru all of the dependencies from the link you provided and all are installed.
Not sure where to go now. Probably something simple.
smilliken
Post by smilliken »
OK, this blows my mind. I have an install of Ubuntu 10.04 and installed Zoneminder and went thru the tutorial and I have no problem adding a monitor and all of the tabs work.
It is showing red, but that is a matter of tweaking.
I'd like to know why the other distros don't work. Even tried a 4.6.2 version of KDE :shock:
smilliken
Post by smilliken »
Bump.
