Hi!
I want use ZoneMinder to capture images from cameras every 5 minutes.
It's necessary for my boss - documenting new headquarter build.
It's possible?
Thanks!
Capturing images every 5 minutes ?
Re: Capturing images every 5 minutes ?
Click on the source column for the camera, on the general tab change maximum frame rate to a value less then 1 (i.e. a .5 value will yield 1 frame per two seconds). 0.0033 should be close; do the math and time the setup to verify.
I did exactly this for our new office build, and afterwards created a 2 minute film of the whole process.
I didn't use zm.
The stages.
1. Capture sequentially named jpgs from a camera every x minutes (I think I used 10, but 5's good too). I did this by using crontab to call a small perl script which looked at the directory, found the highest numbered file, then fetched a new jpg and saved it as highest_number + 1.jpg. I was using a solidly mounted Axis ip cam.
2. Backup the jpgs!
3. Deleted all the night time jpgs. Just viewed the big directory full of thumbnails and deleted all the dark ones. You can leave this if you want the artistry, but I found it distracting, wasteful and sometimes quite headache inducing.
4. Ran ffmpeg to convert the directory full of files into an avi. It took a few attempts to drop several frames to get the desired film length.
The resulting film was very well received by all who saw it, especially the estonian construction crew. We had a big language barrier but this was a nice way to say thank you, and I gave them all copies of it to take home.
You could do this with zm, and would cut a lot of the stages out, but you'd probably end up with several movies, but they could be stitched together fairly easily afterwards.
I didn't use zm.
The stages.
2. Backup the jpgs!
I've tried but it doesn't work good. Sometimes recording stopping (in log "Waiting for capture daemon") another time web interface is not availablebb99 wrote:Click on the source column for the camera, on the general tab change maximum frame rate to a value less then 1 (i.e. a .5 value will yield 1 frame per two seconds). 0.0033 should be close; do the math and time the setup to verify.
With continous recording all work good.
What command I can use for capturing images (for configured monitors) using cron ?
I forget my method, probably done in perl - but a quick google brings this - and many others which may help;
http://www.streamreader.org/serverfault ... -extension
