zoneminder now fail's to start
get this error as do every one else with the dvd installed
any ideas
i see libavcore has a bug listed against when i search Google
"Starting ZoneMinder: /usr/local/bin/zmfix: error while loading shared libraries: libavcore.so.0: cannot open shared object file: No such file or directory
failure"
re posted from this thread
http://www.zoneminder.com/forums/viewto ... =6&t=12915
Ubuntu upgrade killed ffmpeg libavcore.
I donated have YOU?
Re: Ubuntu upgrade killed zoneminder "libavcore.so.0"
libavcore.so is not part of ZoneMinder, but ffmpeg.
Have you tried to reinstall ffmpeg?
mastertheknife.
mastertheknife.
Kfir Itzhak.
yea i have
followed heaps of versions on the wiki
still wont start, same error
i am getting a bit lost now
there is talk around the sites i have visited about ffmpeg
the best example from http://ffmpeg.org/pipermail/ffmpeg-user ... 00102.html
is
On date Thursday 2011-03-24 15:57:49 -0400, Leo Izen encoded:
> Whatever happened to libavcore? Now I don't see libavcore.
Was merged into libavutil.
is
I donated have YOU?
Do we have a fix for this yet?
My system desided to do an auto-update for me, and now zoneminder is broken.
Is there anyway to rollback the updates?
Best Regards.
Best Regards.
Don't know
but if i do a virgin install is it going to strike again
i do not know enough about linux to know
I donated have YOU?
