Fresh install on Mint Linux
bsagowitz
Post by bsagowitz »
Any help would be greatly appreciated.
Info:
Mint Linux 10 32bit
used apt-get to install zoneminder 1.24.2-7
I am able to get to zm console webpage
but when I add a Axis 207 netcam I see a black screen.
This is how I set the camera settings
General Tab:
Source Type: Remote
Function Monitor
Source:
Remote Protocol HTTP
Remote Method Simple
Remote Host Name IP address
Remote Host Port 80
Remote Host Path /mjpg/video.mjpg
Remote Image Colours 24bit
Width 640
Height 480
Here is the output of my logs:
tail /tmp/zm*.log
==> /tmp/zmaudit.log <==
==> /tmp/zmdc.log <==
05/06/2011 09:23:35.112160 zmdc[1300].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/06/2011 09:26:15.014554 zmdc[1300].INF [Starting pending process, zmc -m 1]
05/06/2011 09:26:15.015288 zmdc[1300].INF ['zmc -m 1' starting at 11/05/06 09:26:15, pid = 2696]
05/06/2011 09:26:15.107770 zmdc[1300].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/06/2011 09:31:35.001106 zmdc[1300].INF [Starting pending process, zmc -m 1]
05/06/2011 09:31:35.001780 zmdc[1300].INF ['zmc -m 1' starting at 11/05/06 09:31:35, pid = 4101]
05/06/2011 09:31:35.109808 zmdc[1300].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/06/2011 09:41:35.032275 zmdc[1300].INF [Starting pending process, zmc -m 1]
05/06/2011 09:41:35.032942 zmdc[1300].INF ['zmc -m 1' starting at 11/05/06 09:41:35, pid = 6543]
05/06/2011 09:41:35.125235 zmdc[1300].ERR ['zmc -m 1' exited abnormally, exit status 255]
==> /tmp/zmfilter.log <==
05/06/2011 09:21:01.032623 zmfilter[1337].INF [Scanning for events]
==> /tmp/zmpkg.log <==
05/06/2011 09:20:52.872005 zmpkg[1269].INF [Command: start]
==> /tmp/zmwatch.log <==
05/06/2011 09:49:41.032160 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:49:51.032697 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:50:01.033229 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:50:11.033760 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:50:21.034288 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:50:31.034802 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:50:41.035305 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:50:51.035822 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:51:01.036322 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/06/2011 09:51:11.036877 zmwatch[1343].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
KeithB
Re: Fresh install on Mint Linux
Post by KeithB »
This is likely a shared memory problem. Try the script suggested here:
http://www.zoneminder.com/forums/viewto ... 21&t=17595
You would probably find that if you reduced the resolution to 320 x 240 it would work and that would confirm it as a shared memory problem.
bsagowitz
Post by bsagowitz »
made the changes and restarted the server... this is what I get.
05/09/2011 12:02:41.097380 zmdc[2178].INF [Server starting at 11/05/09 12:02:41]
05/09/2011 12:02:44.196325 zmdc[2178].INF ['zmc -m 1' starting at 11/05/09 12:02:44, pid = 2200]
05/09/2011 12:02:44.267128 zmdc[2178].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/09/2011 12:02:44.267320 zmdc[2178].INF [Starting pending process, zmc -m 1]
05/09/2011 12:02:44.267896 zmdc[2178].INF ['zmc -m 1' starting at 11/05/09 12:02:44, pid = 2203]
05/09/2011 12:02:44.299991 zmdc[2178].INF ['zmfilter.pl' starting at 11/05/09 12:02:44, pid = 2204]
05/09/2011 12:02:44.307870 zmdc[2178].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/09/2011 12:02:44.400913 zmdc[2178].INF ['zmaudit.pl -c' starting at 11/05/09 12:02:44, pid = 2206]
05/09/2011 12:02:44.501751 zmdc[2178].INF ['zmwatch.pl' starting at 11/05/09 12:02:44, pid = 2208]
05/09/2011 12:02:49.008624 zmdc[2178].INF [Starting pending process, zmc -m 1]
05/09/2011 12:02:49.009277 zmdc[2178].INF ['zmc -m 1' starting at 11/05/09 12:02:49, pid = 2210]
05/09/2011 12:02:49.045140 zmdc[2178].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/09/2011 12:02:59.028749 zmdc[2178].INF [Starting pending process, zmc -m 1]
05/09/2011 12:02:59.029417 zmdc[2178].INF ['zmc -m 1' starting at 11/05/09 12:02:59, pid = 2264]
05/09/2011 12:02:59.065088 zmdc[2178].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/09/2011 12:03:19.091832 zmdc[2178].INF [Starting pending process, zmc -m 1]
05/09/2011 12:03:19.092522 zmdc[2178].INF ['zmc -m 1' starting at 11/05/09 12:03:19, pid = 2266]
05/09/2011 12:03:19.122005 zmdc[2178].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/09/2011 12:03:59.076677 zmdc[2178].INF [Starting pending process, zmc -m 1]
05/09/2011 12:03:59.077360 zmdc[2178].INF ['zmc -m 1' starting at 11/05/09 12:03:59, pid = 2275]
05/09/2011 12:03:59.114993 zmdc[2178].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/09/2011 12:02:44.607721 zmfilter[2204].INF [Scanning for events]
05/09/2011 12:02:38.613327 zmpkg[2168].INF [Command: start]
05/09/2011 12:02:44.601982 zmwatch[2208].INF [Watchdog starting]
05/09/2011 12:02:44.602325 zmwatch[2208].INF [Watchdog pausing for 30 seconds]
05/09/2011 12:03:24.603745 zmwatch[2208].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/09/2011 12:03:34.604304 zmwatch[2208].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/09/2011 12:03:44.604857 zmwatch[2208].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
05/09/2011 12:03:54.605396 zmwatch[2208].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
brad@duncan ~/Desktop $ sudo ./shared.sh
--- Checking memory setting...
-- Total memory = 2040442880 B = 1945 MB
-- Page size = 4096 B
-- Current kernel.shmmax = 1836398592 B = 1751 MB
-- Current kernel.shmall = 498155 pages
-- Recommended shm values already set
--- Done.
bsagowitz
Post by bsagowitz »
nevermind. dumb mistake on my part.
Camera was not set to anonymous login
