NO RECORD ON IP CAMERA
dj_pato
Post by dj_pato »
Hello everyone,
The program starts and after a few seconds it stops working
DEBUG:
May 11 02:02:46 FCM-Security-Server zmdc[3685]: INF [Starting pending process, zmc -m 2]
May 11 02:02:46 FCM-Security-Server zmdc[3685]: INF ['zmc -m 2' starting at 11/05/11 02:02:46, pid = 3727]
May 11 02:02:46 FCM-Security-Server zmdc[3727]: INF ['zmc -m 2' started at 11/05/11 02:02:46]
May 11 02:02:46 FCM-Security-Server zmc_m2[3727]: INF [Debug Level = 0, Debug Log = <none>]
May 11 02:02:46 FCM-Security-Server zmc_m2[3727]: INF [Starting Capture]
May 11 02:02:48 FCM-Security-Server zmc_m2[3727]: ERR [Select timed out]
May 11 02:02:48 FCM-Security-Server zmc_m2[3727]: ERR [Unable to read content]
May 11 02:02:48 FCM-Security-Server zmc_m2[3727]: ERR [Unable to get response]
May 11 02:02:48 FCM-Security-Server zmc_m2[3727]: ERR [Failed to capture image from monitor 2 (0/1)]
May 11 02:02:48 FCM-Security-Server zmdc[3685]: ERR ['zmc -m 2' exited abnormally, exit status 255]
May 11 02:02:58 FCM-Security-Server zmdc[3685]: INF [Starting pending process, zmc -m 2]
May 11 02:02:58 FCM-Security-Server zmdc[3685]: INF ['zmc -m 2' starting at 11/05/11 02:02:58, pid = 3729]
May 11 02:02:58 FCM-Security-Server zmdc[3729]: INF ['zmc -m 2' started at 11/05/11 02:02:58]
May 11 02:02:58 FCM-Security-Server zmc_m2[3729]: INF [Debug Level = 0, Debug Log = <none>]
May 11 02:02:58 FCM-Security-Server zmc_m2[3729]: INF [Starting Capture]
May 11 02:03:00 FCM-Security-Server zmc_m2[3729]: ERR [Select timed out]
May 11 02:03:00 FCM-Security-Server zmc_m2[3729]: ERR [Unable to read content]
May 11 02:03:00 FCM-Security-Server zmc_m2[3729]: ERR [Unable to get response]
May 11 02:03:00 FCM-Security-Server zmc_m2[3729]: ERR [Failed to capture image from monitor 2 (0/1)]
May 11 02:03:00 FCM-Security-Server zmdc[3685]: ERR ['zmc -m 2' exited abnormally, exit status 255]
I GOOGLE THIS PROBLEM BUT I CAN´T FIND ANY SOLUTION!
HELPPP PLEASE!!!
THANKSSSSSSSSSSSSSS
Flasheart
Re: NO RECORD ON IP CAMERA
Post by Flasheart »
Not enough information.
What ip camera is it, and what are your settings in the monitor (source tab) ?
dj_pato
Post by dj_pato »
This is the camera:
300k-pixel-ip-network-internet-surveillance-ip-camera-35425
ON DEALEXTREME
(Cannot put URLs SORRY!)
Mi config for the camera is:
Remote Protocol HTTP
Remote Method Simple
Remote Host Name 192.168.120.2
Remote Host Port 80
Remote Host Path /image.jpg
Remote Image Colours 24 bit colour
Capture Width (pixels) 640
Capture Height (pixels) 480
The camera works OK but zoneminder stops working after a few seconds!
HELP PLEASE!
Flasheart
Post by Flasheart »
When you visit http://192.168.120.2/image.jpg in a browser you get a static jpg that is exactly 640x480?
If so, great. But zm won't work out of the box on 640x480 without a quick tweak.
Now - read the FAQ and follow the steps in the section on shared memory;
http://www.zoneminder.com/wiki/index.ph ... esolutions.
If you're still having problems after doing that, check your logs - zm.log or relevant bits from syslog and post any likely looking error messages back here.
KeithB
Post by KeithB »
What frame rate are you using and did you set it on the camera or in Zoneminder?
