Problem configuring source
cmendes0101
Post by cmendes0101 »
This is my first time installing ZoneMinder and im having an issue doing the ./configure. Here is the line I'm using:
./configure --with-mysql=/usr/include/mysql/ --with-ffmpeg=/usr/src/ffmpeg --with-extralibs --with-webdir=/var/www/zm --with-cgidir=/var/www/zm/cgi-bin --with-libarch=lib
This is the error that im getting from the config.log:
configure:3387: checking whether the C++ compiler works
configure:3409: g++  -I/usr/src/ffmpeg/include  -L/usr/src/ffmpeg/lib -L/usr/include/mysql//lib/mysql  yes conftest.cpp  >&5
g++: yes: No such file or directory
configure:3413: $? = 1
configure:3451: result: no
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "zm"
| #define PACKAGE_TARNAME "ZoneMinder"
| #define PACKAGE_VERSION "1.24.3"
| #define PACKAGE_STRING "zm 1.24.3"
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| #define PACKAGE "ZoneMinder"
| #define VERSION "1.24.3"
| #define ZM_MEM_MAPPED 1
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:3456: error: in `/usr/src/ZoneMinder-1.24.3':
configure:3460: error: C++ compiler cannot create executables
See `config.log' for more details.
It appears to be the 2nd line in the log but not sure what I can do to correct that. Any info would help. Thanks
mastertheknife
Re: Problem configuring source
Post by mastertheknife »
It complains about g++ not being available on your system, which is actually part of gcc.
mastertheknife.
Kfir Itzhak.
cmendes0101
I have g++ already installed. I've compiled a few other pieces of software with out any issue that used g++ and gcc.
Is there really a file that is called "yes" that is put in the command for g++?
zoneminder
Site Admin
Post by zoneminder »
What happens if you manually reproduce the steps that configure does? In other words create a file with the same contents and try and compile it with the same command.
Phil
cmendes0101
I'm not really sure what contents to put in the file to try and put in there. Would you be able to suggest what its trying to run so I could try that out?
cmendes0101
Found it!
I has left this "--with-extralibs" on the ./configure line. When I took it out it was able to complete
