http://www.zoneminder.com/wiki/index.php/Kodicom_8800
Problem is Ubuntu modprobes VERY VERY slowly each chip
the 8x video chips are
CONEXANT
Fusion 878A
25878-13
0505Y1F9
0505 TAIWAN
PLX
PCI6150-BB66PC
A0504
V45937.1 TAIWAN
A fairchild LCX244
A ATMEL 24CO2M CMOS?
28.63636 Crystal
LSPCI -n results trimmed
07:0f.0 0400: 109e:036e (rev 11)
07:0f.1 0480: 109e:0878 (rev 11)
07:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 15
Memory at e7a0e000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
Kernel modules: bttv
07:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at e7a0f000 (32-bit, prefetchable) [size=4K]
THE PCI CHIP
description: PCI bridge
product: HiNT HB4 PCI-PCI Bridge (PCI6150)
vendor: Hint Corp
physical id: 0
bus info: pci@0000:06:00.0
version: 04
width: 32 bits
clock: 33MHz
capabilities: pci pm hotswap vpd normal_decode bus_master cap_list
resources: ioport:e7a00000(size=1048576)
*-multimedia:0
description: Multimedia video controller
product: Bt878 Video Capture
vendor: Brooktree Corporation
physical id: 8
bus info: pci@0000:07:08.0
version: 11
width: 32 bits
clock: 33MHz
capabilities: vpd pm bus_master cap_list
configuration: driver=bttv latency=32 maxlatency=40 mingnt=16
resources: irq:20 memory:e7a00000-e7a00fff
*-multimedia:1 UNCLAIMED
description: Multimedia controller
product: Bt878 Audio Capture
physical id: 8.1
bus info: pci@0000:07:08.1
version: 11
width: 32 bits
clock: 33MHz
configuration: latency=32 maxlatency=255 mingnt=4
resources: memory:e7a01000-e7a01fff
note the amount of time betweent each card almost 2 minutes
david@ubuntu-server1:~$ dmesg | grep bttv
[ 11.902860] bttv: driver version 0.9.18 loaded
[ 11.902862] bttv: using 16 buffers with 2080k (520 pages) each for capture
[ 11.902900] bttv: Bt8xx card found (0).
[ 11.902923] bttv 0000:07:08.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 11.902933] bttv0: Bt878 (rev 17) at 0000:07:08.0, irq: 20, latency: 32, mmio: 0xe7a00000
[ 11.903276] bttv0: using: IVC-200 [card=102,insmod option]
[ 11.903315] bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 11.903359] bttv0: tuner absent
[ 11.903360] bttv0: the autoload option is obsolete.
[ 11.903361] bttv0: use option msp3400, tda7432 or tvaudio to
[ 11.903363] bttv0: override which audio module should be used.
[ 11.903406] bttv0: registered device video0
[ 11.903428] bttv0: registered device vbi0
[ 11.903454] bttv0: PLL: 28636363 => 35468950 ..
[ 108.420216] bttv: Bt8xx card found (1).
[ 108.420235] bttv 0000:07:09.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 108.420247] bttv1: Bt878 (rev 17) at 0000:07:09.0, irq: 19, latency: 32, mmio: 0xe7a02000
[ 108.420328] bttv1: using: IVC-200 [card=102,insmod option]
[ 108.420359] bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 108.420415] bttv1: tuner absent
[ 108.420417] bttv1: the autoload option is obsolete.
[ 108.420418] bttv1: use option msp3400, tda7432 or tvaudio to
[ 108.420419] bttv1: override which audio module should be used.
[ 108.420484] bttv1: registered device video1
[ 108.420507] bttv1: registered device vbi1
[ 108.420535] bttv1: PLL: 28636363 => 35468950 .
[ 108.421565] bttv1: PLL: 28636363 => 35468950 .
[ 108.421572] bttv1: PLL: 28636363 => 35468950 .. ok
[ 204.923776] bttv: Bt8xx card found (2).
[ 204.923792] bttv 0000:07:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 204.923803] bttv2: Bt878 (rev 17) at 0000:07:0a.0, irq: 18, latency: 32, mmio: 0xe7a04000
[ 204.923862] bttv2: using: IVC-200 [card=102,insmod option]
[ 204.923889] bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 204.923939] bttv2: tuner absent
[ 204.923941] bttv2: the autoload option is obsolete.
[ 204.923942] bttv2: use option msp3400, tda7432 or tvaudio to
[ 204.923944] bttv2: override which audio module should be used.
[ 204.923997] bttv2: registered device video2
[ 204.924023] bttv2: registered device vbi2
[ 204.924048] bttv2: PLL: 28636363 => 35468950 .
[ 204.925047] bttv2: PLL: 28636363 => 35468950 .
[ 204.925208] bttv2: PLL: 28636363 => 35468950 .. ok
[ 301.443779] bttv: Bt8xx card found (3).
[ 301.443796] bttv 0000:07:0b.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 301.443809] bttv3: Bt878 (rev 17) at 0000:07:0b.0, irq: 16, latency: 32, mmio: 0xe7a06000
[ 301.443854] bttv3: using: IVC-200 [card=102,insmod option]
[ 301.443882] bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 301.443935] bttv3: tuner absent
[ 301.443936] bttv3: the autoload option is obsolete.
[ 301.443938] bttv3: use option msp3400, tda7432 or tvaudio to
[ 301.443939] bttv3: override which audio module should be used.
[ 301.443995] bttv3: registered device video3
[ 301.444021] bttv3: registered device vbi3
[ 301.444050] bttv3: PLL: 28636363 => 35468950 .
[ 301.445143] bttv3: PLL: 28636363 => 35468950 .
[ 301.445404] bttv3: PLL: 28636363 => 35468950 .. ok
[ 397.940426] bttv: Bt8xx card found (4).
[ 397.940442] bttv 0000:07:0c.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 397.940453] bttv4: Bt878 (rev 17) at 0000:07:0c.0, irq: 20, latency: 32, mmio: 0xe7a08000
[ 397.940496] bttv4: using: IVC-200 [card=102,insmod option]
[ 397.940523] bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 397.940574] bttv4: tuner absent
[ 397.940576] bttv4: the autoload option is obsolete.
[ 397.940577] bttv4: use option msp3400, tda7432 or tvaudio to
[ 397.940579] bttv4: override which audio module should be used.
[ 397.940632] bttv4: registered device video4
[ 397.940663] bttv4: registered device vbi4
[ 397.940688] bttv4: PLL: 28636363 => 35468950 .
[ 397.941709] bttv4: PLL: 28636363 => 35468950 .
[ 397.941878] bttv4: PLL: 28636363 => 35468950 .. ok
[ 494.443779] bttv: Bt8xx card found (5).
[ 494.443797] bttv 0000:07:0d.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 494.443810] bttv5: Bt878 (rev 17) at 0000:07:0d.0, irq: 19, latency: 32, mmio: 0xe7a0a000
[ 494.443854] bttv5: using: IVC-200 [card=102,insmod option]
[ 494.443882] bttv5: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 494.443938] bttv5: tuner absent
[ 494.443939] bttv5: the autoload option is obsolete.
[ 494.443940] bttv5: use option msp3400, tda7432 or tvaudio to
[ 494.443942] bttv5: override which audio module should be used.
[ 494.443998] bttv5: registered device video5
[ 494.444027] bttv5: registered device vbi5
[ 494.444054] bttv5: PLL: 28636363 => 35468950 .
[ 494.445208] bttv5: PLL: 28636363 => 35468950 .
[ 494.445289] bttv5: PLL: 28636363 => 35468950 .. ok
[ 590.943778] bttv: Bt8xx card found (6).
[ 590.943798] bttv 0000:07:0e.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 590.943811] bttv6: Bt878 (rev 17) at 0000:07:0e.0, irq: 18, latency: 32, mmio: 0xe7a0c000
[ 590.943858] bttv6: using: IVC-200 [card=102,insmod option]
[ 590.943888] bttv6: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 590.943940] bttv6: tuner absent
[ 590.943941] bttv6: the autoload option is obsolete.
[ 590.943943] bttv6: use option msp3400, tda7432 or tvaudio to
[ 590.943944] bttv6: override which audio module should be used.
[ 590.944003] bttv6: registered device video6
[ 590.944031] bttv6: registered device vbi6
[ 590.944058] bttv6: PLL: 28636363 => 35468950 .
[ 590.944987] bttv6: PLL: 28636363 => 35468950 .
[ 590.945168] bttv6: PLL: 28636363 => 35468950 .. ok
[ 687.440056] bttv: Bt8xx card found (7).
[ 687.440072] bttv 0000:07:0f.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 687.440084] bttv7: Bt878 (rev 17) at 0000:07:0f.0, irq: 16, latency: 32, mmio: 0xe7a0e000
[ 687.440128] bttv7: using: IVC-200 [card=102,insmod option]
[ 687.440156] bttv7: gpio: en=00000000, out=00000000 in=00ffffff [init]
[ 687.440208] bttv7: tuner absent
[ 687.440209] bttv7: the autoload option is obsolete.
[ 687.440211] bttv7: use option msp3400, tda7432 or tvaudio to
[ 687.440212] bttv7: override which audio module should be used.
[ 687.440269] bttv7: registered device video7
[ 687.440296] bttv7: registered device vbi7
[ 687.440323] bttv7: PLL: 28636363 => 35468950 .
[ 687.441289] bttv7: PLL: 28636363 => 35468950 .
[ 687.441537] bttv7: PLL: 28636363 => 35468950 .. ok
david@ubuntu-server1:~$ cat /etc/modprobe.d/bttv.conf
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
modprobe is at 100% for each card sitting there doing nothing. how else can i debug ?
