Just to let you know, today I installed a new Ubuntu Desktop 11.04 and used this install guide on this page:
http://www.zoneminder.com/wiki/index.ph ... _Cambozola
And it worked like a charm!
One step uses nano to manually edit several src files:
#Edit files below, or ZoneMinder will not compile
nano src/zm_ffmpeg_camera.cpp # change “CODEC_TYPE_VIDEO” to “AVMEDIA_TYPE_VIDEO”
nano src/zm_mpeg.cpp # change “PKT_FLAG_KEY” to “AV_PKT_FLAG_KEY”
nano src/zm_mpeg.cpp # change “CODEC_TYPE_VIDEO” to “AVMEDIA_TYPE_VIDEO”
nano src/zm_remote_camera_rtsp.cpp # change as before
nano src/zm_rtsp.cpp # change as before
nano src/zm_sdp.cpp # change all CODEC_TYPE_ to AVMEDIA_TYPE_
nano src/zm_sdp.h # change “enum CodecType” to “enum AVMediaType”
I found the above instructions hard to follow, so I wrote a script to do them all below, the lines below replace above nano lines:
### script to edit cpp files using sed so they compile on Ubuntu 11.04
sed 's/CODEC_TYPE_VIDEO/AVMEDIA_TYPE_VIDEO/g' zm_ffmpeg_camera.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_ffmpeg_camera.cpp
sed 's/PKT_FLAG_KEY/AV_PKT_FLAG_KEY/g' zm_mpeg.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_mpeg.cpp
sed 's/CODEC_TYPE_VIDEO/AVMEDIA_TYPE_VIDEO/g' zm_mpeg.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_mpeg.cpp
# zm_remote_camera_rtsp.cpp # change as before
sed 's/PKT_FLAG_KEY/AV_PKT_FLAG_KEY/g' zm_remote_camera_rtsp.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_remote_camera_rtsp.cpp
sed 's/CODEC_TYPE_VIDEO/AVMEDIA_TYPE_VIDEO/g' zm_remote_camera_rtsp.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_remote_camera_rtsp.cpp
# zm_rtsp.cpp # change as before
sed 's/PKT_FLAG_KEY/AV_PKT_FLAG_KEY/g' zm_rtsp.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_rtsp.cpp
sed 's/CODEC_TYPE_VIDEO/AVMEDIA_TYPE_VIDEO/g' zm_rtsp.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_rtsp.cpp
sed 's/CODEC_TYPE_/AVMEDIA_TYPE_/g' zm_sdp.cpp > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_sdp.cpp
sed 's/enum CodecType/enum AVMediaType/g' zm_sdp.h > /tmp/ptmp.cpp ; mv /tmp/ptmp.cpp zm_sdp.h
# -------------- end of script -----------------
It saves time vs doing the manual edits.
Zoneminder 1.24.3 deluxe on Ubuntu 11.04 Natty
Running Ubuntu 11.04 64bit Zoneminder 1.24.3 from SVN, FFmpeg, libjpeg-turbo, Webmin, Cambozola
Re: Zoneminder 1.24.3 deluxe on Ubuntu 11.04 Natty
Hi Nogero,
I added your script to my 11.04 Wiki article! Thanks for your addition!
I'm having issues following the wiki guide
zm_mpeg.cpp: In member function âvoid VideoStream::SetParameters()â:
zm_mpeg.cpp:133:7: warning: âint av_set_parameters(AVFormatContext*, AVFormatParameters*)â is deprecated (declared at /usr/local/include/libavformat/avformat.h:1334)
zm_mpeg.cpp:133:34: warning: âint av_set_parameters(AVFormatContext*, AVFormatParameters*)â is deprecated (declared at /usr/local/include/libavformat/avformat.h:1334)
zm_mpeg.cpp: In member function âdouble VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)â:
zm_mpeg.cpp:359:16: error: âAV_AV_PKT_FLAG_KEYâ was not declared in this scope
zm_mpeg.cpp:390:18: error: âAV_AV_PKT_FLAG_KEYâ was not declared in this scope
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/usr/src/zm/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/zm'
make: *** [all] Error 2
root@ubuntu-zoneminder-source64:/usr/src/zm#
I get the above issues Not sure how to proceed
- zoneminder
- Site Admin
- Contact:
It looks like some of the substitutions maybe have run twice? You should be ok if you change the AV_AV_ to just AV_.
Version 1.24.3 has all these changes already made by the way.
Phil
