HI All
Can anybody suggest which preset should be selected while configuring the C1062 P/T model from Clairvoyant. I got these IP cameras from MWR engineering (china)
Thanks in advance.
Prasad
Clairvoyant C1062 model support
Re: Clairvoyant C1062 model support
It's fairly unlikely any of the presets will work.
You will need to find out the web path for either a static jpg (snapshot) or mjpeg stream; or mpeg4 details.
You can then punch those into the zm monitor with x and y and you should be good to go. Quite a few of these chinese cams have similar firmware, so try ip/image.jpg or ip/image.cgi in a web browser and see if you get an image.
Thanks for the information shared.
But I'm still unable to understand how to go about the same. You mean I , don;t have to select any preset drop-downs.
What parameters should i give in
Host Name:
Host port: Port would be 80
Host path:
Please advice
Prasad
Host Name:
Host path:
Please advice
Prasad
