BT878 card… Detected...
tibetfreedom
Re: BT878 card… Detected...
Post by tibetfreedom »
mastertheknife wrote:Same card as mine.
What options do you use in bttv.conf?
Exactly as stated in the docs….
tibetfreedom
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
DREMA
Post by DREMA »
Try just with this,
bttv card=77,77,77,77,77,77,77,77
I use that with my card, and is the same as yours
Just... enjoy life! :D
tibetfreedom
DREMA wrote:Try just with this,
OK and relaod bbtv.conf ?
what should I use to reload ?
tibetfreedom
OK
I get this now…
root@CCTV:/etc/modprobe.d# xawtv -hwscan
xdpyinfo: unable to open display "".
This is xawtv-3.95.dfsg.1, running on Linux/i686 (2.6.32-5-686)
Error: Can't open display:
mastertheknife
Post by mastertheknife »
The 102 settings you used were correct.
I think the card might be defective or its connection to the system might be bad (because of the bus errors).
Try taking out the card, cleaning the PCI pins and PCI slot or try it in a different PCI slot.
mastertheknife.
Kfir Itzhak.
tibetfreedom
mastertheknife wrote:The 102 settings you used were correct.
mastertheknife.
OK Thanks.
I thought it must be.
DREMA
Post by DREMA »
Also don't forget to attach heatsinks to the chips, or your card will fail pretty soon.
tibetfreedom
DREMA wrote:Also don't forget to attach heatsinks to the chips, or your card will fail pretty soon.
Where di Get those from ...?
